iSCSI Boot with NetApp
I have a question about the iSCSI boot with a NetApp.
The configuration in UCSM is like the CVD Flexpod Guide.
I had created two vNics (image01.png + image02.png).
When the blade is booting up, the connection to the NetApp will established. On the NetApp Controller i see the logged in initiator on the igroup:
    IG_ESX03 (iSCSI) (ostype: vmware):
        iqn.2013-12.ch.xxx:esxi03a (logged in on: team01-20)
        iqn.2013-12.ch.xxx:esxi03b (logged in on: team01-30)
Then on the KVM Session i see that ESXi stay at the iscsi_vmk screen (image03.png). After maybe 30 seconds, i execute the igroup show command on the NetApp:
        iqn.2013-12.ch.xxx:esxi03a (logged in on: team01-30, team01-20)
        iqn.2013-12.ch.xxx:esxi03b (logged in on: iscsi (awaiting reconnect))
After more 30 seconds, i saw that team01-30 is not logged in on the second iqn:
        iqn.2013-12.ch.xxx:esxi03b (not logged in)
ESXi starts normally and looks fine. In the storage adapter configuration it looks good. Two paths on FI-A and FI-B (image04.png and image05.png).
Is that normal, that iqn.2013-12.ch.xxx:esxi03b is not logged in.
Thank you.
Best Regards
Patrick
Patrick,
Check the troubleshooting section of Andreas' doc :
http://www.cisco.com/en/US/products/ps10281/products_configuration_example09186a0080bfcb0a.shtml#tshoot
Or my shameless plug:
https://supportforums.cisco.com/docs/DOC-38582#Verification_
(per adapter)
At least it will let us know what's going on in UCS.
M.
Hi Marcin
Here is the output (the customer name is replaced with xxx):
vnic iSCSI Configuration:
vnic_id: 13
          link_state: Up
       Initiator Cfg:
     initiator_state: ISCSI_INITIATOR_READY
initiator_error_code: ISCSI_BOOT_NIC_NO_ERROR
                vlan: 0
         dhcp status: false
                 IQN: iqn.2013-12.ch.xxx:esxi01a
             IP Addr: 172.20.20.101
         Subnet Mask: 255.255.255.0
             Gateway: 0.0.0.0
          Target Cfg:
          Target Idx: 0
               State: ISCSI_TARGET_READY
          Prev State: ISCSI_TARGET_DISABLED
        Target Error: ISCSI_TARGET_NO_ERROR
                 IQN: iqn.1992-08.com.netapp:xxxvfvm01
             IP Addr: 172.20.20.155
                Port: 3260
            Boot Lun: 0
          Ping Stats: Success (11.743ms)
        Session Info:
          session_id: 0
         host_number: 0
          bus_number: 0
           target_id: 0
vnic_id: 14
          link_state: Up
       Initiator Cfg:
                vlan: 0
         dhcp status: false
                 IQN: iqn.2013-12.ch.xxx:esxi01b
             IP Addr: 172.20.30.101
             Gateway: 0.0.0.0
          Target Cfg:
          Target Idx: 0
             IP Addr: 172.20.30.155
                Port: 3260
            Boot Lun: 0
          Ping Stats: Success (19.016ms)
        Session Info:
          session_id: 0
         host_number: 0
          bus_number: 0
           target_id: 0
adapter 1/1/1 (mcp):2#
Thank you.
Patrick,
Does the state here change with time?
If you tell me this state remains the same, it means that we retain probler reachability between UCS and iSCSI target.
IF it changes look at the state transition and error code... You can also try sniffing traffic to see if there's something that might be going wrong on network layer.
M.
354
