MegaRAID requesting a RAID Activation Key
Server is a UCS C240 M3 SFF
with an LSI MegaRAID SAS 9266CV-8i
We are unable to enable RAID 10
This is requesting an activation key.
Can anyone advise on the process to obtain the activation key.
The spec sheet or installation documentation makes no mention of any required license.
1 ACCEPTED SOLUTION
Sean,To create a RAID 10 you
Sean,
To create a RAID 10 you do not have to select "Advanced Software Options" but instead you need to select "Configuration Wizard"  and then select "New Configuration".
We answered a while ago in the community how to configure RAID 10 in the different ways possible (Through the GUI if you are running CIMC 1.5 or later   OR through WebBIOS which is the one you are trying). See this thread https://supportforums.cisco.com/discussion/11977411/ucs-c220-series-server
Please rate ALL helpful answers.
-Kenny
VIP Red
Don't know the answer,
Don't know the answer, however, LSI documentation clearly mentions the procedure, see e.g.
http://www.lsi.com/downloads/Public/Direct%20Assets/LSI/48343-00_Rev_A_ELF_UG.pdf
MegaRAID®
Electronic License Activation
User Guide
and LSI also provides trial keys for 30 days
http://mycusthelp.info/LSI/_cs/AnswerDetail.aspx?inc=8286
I had seen this document.The
The RAID card was purchased as part of the Cisco build.
Do you know if Cisco provide the "License Authorization Code" as stated in the link you provided?
Hi Sean, How many drives do
Hi Sean,
How many drives do you have?
How are you selecting the drives?  Note that with raid 10 you need to create at least 2 drive spans of two disk each to see the raid 10 option.
Can you provide a picture of where are you seeing this request of an activation key?
Did you buy this controller from Cisco?
Hello,See the image attached
See the image attached.
The server has 18 Drives
Have you tried to create the
Have you tried to create the raid 10?  I don't think cisco sales licenses to enable raid 10, this feature should be enable as far as I am concern.
Let me know if you need documents on how to create a raid 10.
If there is documentation on
If there is documentation on the RAID 10 Creation process that would be good.
I have an Engineer who believes that an additional license requires purchasing specifically the part code R2XX-RAID10
However I believe that this is an optional part code that provides for it to be configured in the factory and isn't necessary.
VIP Red
Did you see https:/
Did you see https://communities.cisco.com/thread/13074
Sean,Did the process I
Sean,
Did the process I provided helped you create the RAID10?  If yes, please mark the question as answered so future users can see you found the solution you were looking for, and please rate the other answers if they were useful. (pretty sure they were :) )
-Kenny
Sean,
-Kenny
First, clear the
First, clear the configuration.easy way, use GUI.
On command line:
#Scope chassis
#scope storageadapter slot %d
storageadapter #clear-foreign-config
confirm (Y/N) Y
show physical-drive-count
this is the second way to clear configuration.after this process u can create raid 10. u don't need license to create raid 10. it's setting only
thanks
Hope this help
3116
