Community Member
Memory channel failures
Anyone else seeing memory channel issues. I have 3 out of 41 new B200 M3 nodes that have experienced a memory channel issue.  RAM in locations A0 and A1 fails but when swapped with the RAM in locations F0 and F1 the failure stays with locations A0 and A1.
TAC is aware and looking into the issue.
Everyone's tags (2)
1 REPLY
Hi CSCO, This might be a cpu
Hi CSCO,
This might be a cpu issue or memory slot issue.  Try swapping the CPUs in your server and see if the problem follow the cpu or stays in the memory slot.
Let me know if this helps, and don't forget to rate any useful posts.
49
