Memory fault UCS C200 m1
We just received two UCS C200 M1 systems with 4GB (2 DIMMS) each. Whenever we boot either system, the memory fault and system fault lights come on. The CIMC log says that there is a moderate fault, but none of the internal memory fault lights are on.I have tried a few different configurations as far as which slots the DIMMS are installed in, but always get the same result.
When I log into the system, it shows the correct amount of memory and seems to be functioning correctly.
Does anyone have any idea what is going on?
1 REPLY
Re: Memory fault UCS C200 m1
If you have only one processor then server displays errors regarding memory. Bug ID is CSCte19858. It should be fixed by the end of January ..
BR, Robert.
949
