N2k connectivity with n5k and 6140 FI
Hi Expert,
i have two n5k and two 6140 FI and four 2148 fex and my ucs manger v is 2.0,please let me what is best practice to connect c series server in this enviroment so that i cam manage my c series servers from UCS and they can alos see my EMC luns.
kshitij
Re: N2k connectivity with n5k and 6140 FI
Hi Kshitij,
The 2148 FEX is not supported for UCSM C-Series integration instead, you would need to get a 2232.  If  don’t want to get new FEXes (2232) you will need to upgrade your UCS environment to the 2.2 firmware release where Direct attach is now supported see below. Note that not all the C-series servers are supported on this mode, so please read the documentation below.  This documented also have the best practice when integration c-series servers with UCSM.  Finally, once you have these servers integrated with UCS you will be able to assign service profiles like the B-series servers and assign boot policies that uses your SAN (boot from SAN).
UCSM 2.2 C-Series Integration
Direct Connect Mode (page 23)
http://www.cisco.com/en/US/docs/unified_computing/ucs/c-series_integration/ucsm2.2/b_C-Series-Integration_UCSM2-2.pdf
Let me know if you have any questions and dont forget to rate useful answers.
Hi Velasco,
Thanks for reply.
Need one more suggestion can my N2k connect to n5k to see attached LUN from emc,if i can not connect them to FI.
kshitij
Kshitij,
Yes, you can connect your N2k to the N5K if you need extra ports.
http://blog.scottlowe.org/2010/11/30/connecting-a-nexus-2148-to-a-nexus-5010/
See the documentation below for connectivity solutions with the UCS and Nexus 5K
Connectivity Solutions for the Cisco Unified Computing System
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/white_paper_c11-623265.html
If you need best practices documents to connect from the N5K to the storage (EMC), I recommend that you contact EMC for their recommendations.
376
