Nexus 1000v 4.2(1)SV2(2.1a) - License Question
I have two VSM's (vm's) running in HA pair on two blade servers in same HP chassis. In the beginning I was running the 1000v environment using the Eval licensing but now I have installed the Cisco provided license files.
My question is this: When I invoke the command "show license usage NEXUS1000V_LAN_SERVICES_PKG" I see the 6 installed Licenses, however, I also see that the "Installed Licenses in Use equals 0.  Should I see Installed Licenses in Use equal 2?
vdivc01-n1kv# show license usage NEXUS1000V_LAN_SERVICES_PKG
Feature Usage Info
      Installed Licenses : 6
    Default Eval Licenses : 0
   Max Overdraft Licenses : 16
Installed Licenses in Use : 0
Overdraft Licenses in Use : 0
  Default Eval Lic in Use : 0
   Default Eval days left : 0
       Licenses Available : 22
          Shortest Expiry : Never
vdivc01-n1kv# show mod vem license-info
Licenses are Sticky
Mod   Socket Count   License Usage Count   License Version   License Status
3     2              -                     -                 licensed
4     2              -                     -                licensed
vdivc01-n1kv# sho license brie
N1KVFEAT201312300740270040.lic
N1KVFEAT201312300741200540.lic
N1KVFEAT201312300742010570.lic
N1KVFEAT201312300742330820.lic
N1KVFEAT201312300743060900.lic
N1KVFEAT201312300743430650.lic
Any help is very appreciated!
David
Everyone's tags (5)
1 ACCEPTED SOLUTION
The installed licenses are used for Advanced Edition.  I suspect your switch is still in Essential Edition mode since there isn't a Count or License Version for those modules.  Check output of sh switch edition.
Example:
SV2# sh switch edition
Switch Edition: Advanced  <------
Advanced Features
Feature Name    Feature State
cts             disabled
dhcp-snooping   disabled
vxlan-gateway   enabled
Licenses Available: 22
Licenses In Use: 10    <---------------
License Expiry Date:
Example:
Advanced Features
cts             disabled
That is exactly what it was.
I switched it from Essential to Advanced and now I see exactly what I was expecting to see.
Feature Usage Info
Installed Licenses in Use : 4
       Licenses Available : 18
Application
VEM 3 - Socket 1
VEM 3 - Socket 2
VEM 4 - Socket 1
VEM 4 - Socket 2
Thank you Matthew for the help!
338
作成コンテンツを作成するには してください
