Nexus 1010 boot failed
MENG YUAN HSIEH
Hi all,
I tried to boot nexus 1010, but only cimc can login. The serial console did not show any information, and still no response. So I tried to connect keyboard and monitor, both are no response. In addition, the nic port is down too.
Have any idea? Or who to troubleshooting it?
6 Replies 6
padramas
Hello Meng,
Are you able to access the CIMC via web browser ?
If yes, do you observe any error messages ?
Any output on the KVM console ?
Padma
MENG YUAN HSIEH
Hello Padma,
-> Yes.
-> No! All the status is "Good".
-> No! The KVM show "No Signal".
Hello Meng,
Has this server worked before ?
Are you able to access the N1010 host CLI interface by doing SSH to CIMC IP address ?
ssh admin@
connect host
Padma
MENG YUAN HSIEH
Hello Padma,
-> Yes.
-> Yes.
ssh admin@ "connect host" did not show any response, and console can not return to CIMC.
When you reboot N1010 from the KVM console, do you see any output?
Hi Yasemin,
After few day later. We used front panel port to connect monitor and keyboard, mouse and reboot it. It is work. But the back of the monitor port still did not work. BTW, the system can work now.
