Nexus 1010 in L3
we are using a single link to connect to the core switches, this link will be carrying all control, management and data traffic.
VEM physical uplinks will also be configured as trunk.
Can gre tunnel for VSM - VEM communication in L3 mode be made on a trunk link? or we need to have a seperate link for control traffic.
NOTE: control0 interface will be used to L3 communication between VSM and VEM.
regards,
sabih
Nexus 1010 in L3
Trunk is fine for L3. One of the steps is to create a veth port-profile to assign a vmware vmknic to. That veth port-profile will be access. I do it all the time with a single uplink. You'll be fine. Just remember to make the vmknic port-porfile l3control and set your system vlans correctly. Here is an example.
Uplink port-profile
n1kv-hyper# show run port-profile uplink-simple
port-profile type ethernet uplink-simple
  switchport mode trunk
  switchport trunk allowed vlan 150-155
  vmware port-group
  no shutdown
  system vlan 150
  state enabled
n1kv-hyper# show run port-profile vm-vlan-150
port-profile type vethernet vm-vlan-150
  capability l3control
  vmware port-group
  switchport mode access
  switchport access vlan 150
  no shutdown
  system vlan 150
  state enabled
Nexus 1010 in L3
I have configured similar port-profiles.
We have deployed VSM on a VM and using vswitch for management purposes therefore mgmt0 is connected to vswitch, and I have configured control0 interface to be used to route l3 traffic.
And added control0 int while configuring svs-domain as L3.
Could you please tell me do we need to configure IP on from the same subnet on vmknic and control0 interface on VSM?
or they can be from different subnets?
and will we be able to ping vmknic IP from VSM? or it is not pingable?
and also please share the svs-domain config aswell, so that I can be sure that the configuration is fine ..
Thank you
Sabih
464
