Community Member
port channels
i am looking at the port channels configured on the FI. And this is it. port channel 21 is (eth 1/27-20) which is connected to the nexus 7000
so what are the rest?
(nxos)# sh port-channel summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
Group Port-       Type     Protocol  Member Ports
      Channel
21    Po21(SU)    Eth      LACP      Eth1/17(P)   Eth1/18(P)   Eth1/19(P)
                                     Eth1/20(P)
1286  Po1286(SU)  Eth      NONE      Eth2/1/9(P)  Eth2/1/10(P)  Eth2/1/11(P)
                                     Eth2/1/12(P)
1293  Po1293(SU)  Eth      NONE      Eth1/1/9(P)  Eth1/1/10(P)  Eth1/1/11(P)
                                     Eth1/1/12(P)
1298  Po1298(SU)  Eth      NONE      Eth1/1/5(P)  Eth1/1/6(P)  Eth1/1/7(P)
                                     Eth1/1/8(P)
1300  Po1300(SU)  Eth      NONE      Eth2/1/5(P)  Eth2/1/6(P)  Eth2/1/7(P)
                                     Eth2/1/8(P)
1306  Po1306(SU)  Eth      NONE      Eth1/1/17(P)  Eth1/1/18(P)  Eth1/1/19(P)
                                     Eth1/1/20(P)
1308  Po1308(SU)  Eth      NONE      Eth2/1/17(P)  Eth2/1/18(P)  Eth2/1/19(P)
                                     Eth2/1/20(P)
1311  Po1311(SU)  Eth      NONE      Eth2/1/13(P)  Eth2/1/14(P)  Eth2/1/15(P)
                                     Eth2/1/16(P)
1312  Po1312(SU)  Eth      NONE      Eth1/1/13(P)  Eth1/1/14(P)  Eth1/1/15(P)
                                     Eth1/1/16(P)
1315  Po1315(SU)  Eth      NONE      Eth2/1/21(P)  Eth2/1/23(P)
1317  Po1317(SU)  Eth      NONE      Eth1/1/21(P)  Eth1/1/23(P)
1 ACCEPTED SOLUTION
Re: port channels
Tony,
Those port channels are those created implicitly by having the appropriate 2nd generation hardware (220x, VIC 1240/80 and 62xx)
Those PC cannot be torn down and can only be seen through NXOS (UCSM-GUI will not show them) < Thanks to my colleague Jeff Allen
There is another discussion in this same forum early this morning:
https://supportforums.cisco.com/message/4013409#4013409
I hope this helps
-Kenny
port channels
Tony,
What is the hardware present here?
7000
  FI's
220X  <<< OR 2104 ????
UCS <<< What adapters are present here???
-Kenny
Community Member
port channels
you are correct
2, 7000s ----> 2 FIs ---------> 2 2208XP-----> UCS (adapters are M81KR, VIC 1240, VIC 1280s)
port channels from FIs to 7Ks
thank you
Re: port channels
Tony,
I hope this helps
-Kenny
port channels
Tony,
We'd appreciate it if you could mark questions which are answered as "answered".  This helps us track open/closed discussions.
Robert
331
