portchannle in UCS any idea about the solution
we create a Portchannel in the UCS but it show up in the switch and in the UCS show failed
since no operatioma member f0727 with this error ??
<faultInst
ack="no"
cause="membership-down"
changeSet=""
code="F0727"
created="2012-01-30T10:25:46"
descr="lan Member 1/19 of Port-Channel 10 on fabric interconnect B is down, membership: individual"
dn="fabric/lan/B/pc-10/ep-slot-1-port-19/fault-F0727"
highestSeverity="major"
id="41644"
lastTransition="2012-01-30T10:25:46"
lc=""
occur="1"
origSeverity="major"
prevSeverity="major"
rule="fabric-eth-lan-pc-ep-down"
severity="major"
status="created"
tags="network,server"
type="network">
</faultInst>
1 ACCEPTED SOLUTION
No.  LACP is the only channeling option.
Robert
Mohammed,
There appears to be an issue with the Port Channel negociation.  UCS FI intefaces can only negociate LACP Port channels, so ensure your upstream switch supports and is configured for LACP (802.3ad).
Once you double check/fix this, disable the Port Channel and then re-enable it.
If you're unsure, post the interface configuration of the upstream switch(es).
Robert
I think they use the nonegotiation mode in the upstream switch it not supported ??
Robert
becuase of that the portchannel in the upstream switch shows SU
I will try to give you the configuration withen 3 hours from now thanks
thaks
also I saw an issue in the chassis 1 as major post faluire error I think due to fan error is that possible
2033
