Power supply voltage upper-non-recoverable
One of our customers is seeing the following errors occur intermittently across all 4 power supplies in their chassis. They are running 2.0(2q). The chassis is powered via an APC UPS and PDUs, and there are no power events or alarms from within the APC InfraStruxure tools. Has anyone else seen these errors in 2.0(2q) or is this error indicating a voltage fluctuation from the UPS?
Sent: Monday, April 30, 2012 6:26 AM
To: ITNotify
Subject: System Notification from PFS-UCS-A - environment:major - 2012-04-30 12:26:39 GMT-00:00 Recovered : Power supply 4 in chassis 1 voltage: upper-non-recoverable
<?xml version="1.0" encoding="UTF-8" ?>
<soap-env:Envelope xmlns:soap-env="http://www.w3.org/2003/05/soap-envelope">
<soap-env:Header>
<aml-session:Session xmlns:aml-session="http://www.cisco.com/2004/01/aml-session" soap-env:mustUnderstand="true" soap-env:role="http://www.w3.org/2003/05/soap-envelope/role/next">
<aml-session:To>http://tools.cisco.com/neddce/services/DDCEService</aml-session:To>
<aml-session:Path>
<aml-session:Via>http://www.cisco.com/appliance/uri</aml-session:Via>
</aml-session:Path>
<aml-session:From>http://www.cisco.com/appliance/uri</aml-session:From>
<aml-session:MessageId>1232:SSI15420KDL:4F9E84FF</aml-session:MessageId>
</aml-session:Session>
</soap-env:Header>
<soap-env:Body>
<aml-block:Block xmlns:aml-block="http://www.cisco.com/2004/01/aml-block">
<aml-block:Header>
<aml-block:Type>http://www.cisco.com/2005/05/callhome/environment</aml-block:Type>
<aml-block:CreationDate>2012-04-30 12:26:39 GMT-00:00</aml-block:CreationDate>
<aml-block:Builder>
<aml-block:Name>UCS 6248 Series Fabric Interconnect</aml-block:Name> <aml-block:Version>5.0(3)N2(2.02q)</aml-block:Version>
</aml-block:Builder>
<aml-block:BlockGroup>
<aml-block:GroupId>1233:SSI15420KDL:4F9E84FF</aml-block:GroupId>
<aml-block:Number>0</aml-block:Number>
<aml-block:IsLast>true</aml-block:IsLast>
<aml-block:IsPrimary>true</aml-block:IsPrimary>
<aml-block:WaitForPrimary>false</aml-block:WaitForPrimary>
</aml-block:BlockGroup>
<aml-block:Severity>6</aml-block:Severity>
</aml-block:Header>
<aml-block:Content>
<ch:CallHome xmlns:ch="http://www.cisco.com/2005/05/callhome" version="1.0">
<ch:EventTime>2012-04-30 12:26:39 GMT-00:00</ch:EventTime> <ch:MessageDescription>Recovered : Power supply 4 in chassis 1 voltage: upper-non-recoverable</ch:MessageDescription>
<ch:Event>
<ch:Type>environment</ch:Type>
<ch:SubType>major</ch:SubType>
<ch:Brand>Cisco</ch:Brand>
<ch:Series>UCS 6248 Series Fabric Interconnect</ch:Series> </ch:Event> <ch:CustomerData> <ch:UserData> <ch:Email>itdept@gopfs.com</ch:Email>
</ch:UserData>
<ch:ContractData>
<ch:SiteId>2089409</ch:SiteId>
<ch:ContractId>90874841</ch:ContractId>
<ch:DeviceId>UCS-FI-6248UP@C@SSI15420KDL</ch:DeviceId>
</ch:ContractData>
<ch:SystemInfo>
<ch:Name>PFS-UCS-A</ch:Name>
<ch:Contact>IT Department</ch:Contact>
<ch:ContactEmail>itdept@gopfs.com</ch:ContactEmail>
<ch:ContactPhoneNumber>+18018442180</ch:ContactPhoneNumber>
<ch:StreetAddress>1420 South 500 West, SLC UT 84115</ch:StreetAddress> </ch:SystemInfo> </ch:CustomerData> <ch:Device> <rme:Chassis xmlns:rme="http://www.cisco.com/rme/4.0">
<rme:Model>UCS-FI-6248UP</rme:Model>
<rme:HardwareVersion>0.0</rme:HardwareVersion>
<rme:SerialNumber>SSI15420KDL</rme:SerialNumber>
</rme:Chassis>
</ch:Device>
</ch:CallHome>
</aml-block:Content>
<aml-block:Attachments>
<aml-block:Attachment type="inline">
<aml-block:Name>sam_content_file</aml-block:Name>
<aml-block:Data encoding="plain">
<![CDATA[
<faultInst
ack="no"
cause="voltage-problem"
changeSet=""
code="F0391"
created="2012-04-30T06:25:39.162"
descr="Power supply 4 in chassis 1 voltage: upper-non-recoverable"
dn="sys/chassis-1/psu-4/fault-F0391"
highestSeverity="critical"
id="218782"
lastTransition="2012-04-30T06:26:39.630"
lc=""
occur="1"
origSeverity="critical"
prevSeverity="critical"
rule="equipment-psu-voltage-threshold-non-recoverable"
severity="cleared"
status="modified"
tags="network,server"
type="environmental"/>]]>
</aml-block:Data>
</aml-block:Attachment>
</aml-block:Attachments>
</aml-block:Block>
</soap-env:Body>
</soap-env:Envelope>
Everyone's tags (4)
Brad,
It looks like the system is running into following defects which is still under investigation.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtx90410
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtz59519
Please open a TAC service request so that we can help you out.
Padma
Re: Power supply voltage upper-non-recoverable
I've had a similar case open recently and I was informed that the PSU's in my case had faulty firmware on them and had to be replaced.
Hope this helps.
3131
