PowerTool Suite (CIMC) 2.0.2.2
When trying to connect to a CIMC, I receive the following error. I haven't found anything on this error.
C:\> Connect-Imc XX.XX.XX.XX
Connect-Imc : Connect-Imc: XX.XX.XX.XX :Invalid CIMC.
At line:1 char:1
+ Connect-Imc XX.XX.XX.XX
    + CategoryInfo          : NotSpecified: (:) [Connect-Imc], Exception
    + FullyQualifiedErrorId : Cisco.Imc.Cmdlets.ConnectImc
Everyone's tags (1)
Greetings.
Greetings.
I ran this against a C240M3 running 2.09f, and output:
Welcome to Cisco IMC PowerTool
Log in to an IMC of standalone UCS server: Connect-Imc
Generate PowerShell code from a running IMC of standalone UCS server: ConvertTo-ImcCmdlet
Show object metadata for all IMC PowerTool cmdlets: Get-ImcCmdletMeta
Once you've connected, display the details of the IMC: Get-ImcRackUnit
If you need more help, visit the IMC PowerTool user community: Get-UcsPow
erToolCommunity
PowerTool C:\> connect-imc x.x.x.x
cmdlet Connect-Imc at command pipeline position 1
Supply values for the following parameters:
Credential
Model : UCSC-C240-M3L
NumPendingConfigs : 0
Imc : ucs-c240-m3
Cookie : wxyz.....
Domains :
LastUpdateTime : 9/4/2016 10:49:46 AM
NoSsl : False
NumWatchers : 0
Port : 443
Priv : {admin}
PromptOnCompleteTransaction : False
Proxy :
RefreshPeriod : 600
SessionId : 29
TransactionInProgress : False
Uri : https://x.x.x.x
UserName : admin
Version : 2.0(9f)
VirtualIpv4Address : x.x.x.x
WatchThreadStatus : None
What type of server, and what version of HUU/firmware is it running?
I am assuming that you can hit the same server with http/https and SSH connection without issue?
Kirk...
It's a C3260 and firmware is
It's a C3260 and firmware is 2.0(9l). We have 2 of these showing the same issue.
I am assuming that you can hit the same server with http/https and SSH connection without issue? - Correct
75
