ql_ima log on ESXi filling up /tmp
Hi All,
anyone come across a ql_ima.log file that fills up the /tmp folder on ESXi 5.5? we are running B200 M3 blades with Cisco ViC 1240.
a quick search on the internet points to users having to update the qlogic driver to fix the issue. if we delete the file, it re-creates it. we dont have a qlogic card in the blade & correct my if i am wrong, but the 1240 would not use a qlogic driver?
any ideas on this?
Kass
hi I am getting same issues
hi
I am getting same issues here. /tmp fiulling up with the qla logs
/tmp # du -sh *
0       0TiTvX
0       6M0k8y
0       8IgI3z
0       9NrykT
0       Cje7LD
0       FQaPHL
0       G90wiw
0       Ki7Zcg
0       MF7zjH
0       NYkNa6
0       QQXsy8
0       QW0LtL
0       TPrkGu
0       UTF5TZ
0       V0Ykq1
0       Zm0ubk
0       altbootbank.lck
0       cNGJeO
0       dpafifo
0       kl0hpE
0       mP04nV
4.0K    probe.session
182.9M  ql_ima.log
4.3M    ql_ima_sdm.log
4.8M    ql_ima_sdm.log_old
0       snmpd-cvtcimsnmp.xml
0       snmpd-vm-report.xml
0       vem-vmkbinding
0       vmY6Mt
8.0K    vmware-root
0       wtMpLb
0       y_79Xo
0       zC_UHX
did you find a solution to this?
thanks
Hi,i dont think we found a
i dont think we found a fix for this, but i will check with my colleague tomorrow who dealt in our team & see if he remembers if there was a fix.
Hi,I believe these are the
I believe these are the articles and the commands we ran to fix our issue:
http://wp.alphaparallel.com/2013/10/vmware-esxi-ram-disk-full-due-to-adaptecs-arcconf-bug/
https://communities.vmware.com/message/2353116
http://www.vdsyn.com/recovering-space-left-device-esxi/
esxcli system visorfs ramdisk list
tmp folder is full
rename the tmp folder
mv/tmp tmp.old
mkdir /tmp
hope this helps.
Anyone find a proper fix for
Anyone find a proper fix for this? Which driver would this be caused by on the B200 M3 and has anyone successfully stopped this from filling up the /tmp by updating the driver?
Or is it fixed in a certain ESXi version?
Marty
Hi All,we seem to have a fix
Hi All,
we seem to have a fix for the ql_ima.log issue. i got in touch with TAC & they advised updating the qlogic driver for our version of ESXi & it has fixed the issue. we are no longer seeing the ql_ima.log being created on the host we applied the fix to. we are rolling this out to other hosts now.
the info from TAC is as follows:
Per our conversation there has been some issues with the inbox driver, updating to the following qlogic driver should resolve the ql_ima.log issues even though this driver is not actually in use by any devices on the blade:
https://my.vmware.com/web/vmware/details?downloadGroup=DT-ESXI55-QLOGIC-QLA4XXX-63455280-1VMW&productId=351
The instructions are in the zip file under DOC/Readme.  Let me know if you have any questions.
hope this helps.
which of these vibs did you
which of these vibs did you install? did you install all?
Hi,i installed:"qla4xxx-634
i installed:
qla4xxx-634.55.28.0-offline_bundle-1682448.zip
3466
