SAN Connectivity to UCS
Hi Guys,
I am working on getting my SAN hooked up with UCS.Below is my confirguation .
There are 2 MDS switches. Each is connected to both SPs. Each HBA will be zoned to a port on each SP.
Two MDS 9500 SAN swtiches and cables are cross connected to the FI so that we have redendency.
NPIV is enabled on  MDS switch. I am getting an error says intailizing and when I look at the speed Indeterminate SAN guy says they are 8.00Gbps.
Not sure what is wrong port are not comming up Green .Can anyone help me please.
3 Accepted Solutions
Brian Morrissey
Hi Srinivas,
What kind of fabric interconnect are you using?  Are the fc uplinks connected to the expansion module on the fi?
Can you ssh into the fabric interconnect and run connect nxos and then show int for that interface?  And do the same on the mds side.
abbharga
Level 4
Level 4
Srinivas,
can you make sure the upstream port on the MDS has been assigned to the correct VSAN. As from the image i can see this port to be part of VSAN 22, the same would have to be done on the MDS port as well.
./Abhinav
@ Srinivas:: So Your problem has been resolved,,,,,
Brian Morrissey
Hi Srinivas,
abbharga
Level 4
Level 4
Srinivas,
./Abhinav
Thanks Guys I am able to figure this out. SAN guys did a cross cablling from FI to MDS instead of A to A and B to B.
