Community Member
Server reboot in a blade
I'm having a UCS issue.
A blade within the UCS chassis was rebooted and begun a reboot cycle.
I tried to reset the server two times without resolution.
I have now tried to do a disassociate of the profile to reapply it.  I cannot remove the profile.  It is stuck with the following error.
    Remote Invocation Result:    End Point Unavailable.
I'm at the customer's site, any ideas?
Saleem
Silver
Hi Saleem,
Which version of UCSM are you running?
Do you have any other faults on the blade / service profile? Screen shots of the faults and the FSM tab will be helpful as well.
Also feel to open a TAC case if this is critical.
Thanks!
./Abhinav
Community Member
Hi Abhinav,
It is back online now, we just reset the fiber link. now it is working , thanks for all.
Saleem
257
