SRE-9XX Quad Core upgrade and ESXi 5?
I am wondering if anyone knows if the SRE-900/910 can support ESXi 5 yet?
Also any plans for a Quad Core option?
Everyone's tags (3)
Richard,
Looks like ESXi 5 is supported, but you may have better luck posting this quesiton to the following forum:
https://supportforums.cisco.com/community/netpro/network-infrastructure/others?view=discussions
I found this thread which details some of the ESXi 5 based support questions.
https://supportforums.cisco.com/message/3619842#3619842
Robert
Hello,I need help of SRE
I need help of SRE configuration and how it's work.
I have SRE 900 k9 and cisco Router 2911. I am trying to configure but i am fail.
My all Router information and Router Configuration.
R1#sh run
Building configuration...
Current configuration : 2196 bytes
! Last configuration change at 04:29:49 UTC Sun Apr 6 2014
version 15.2
hostname R1
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
no aaa new-model
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2911/K9 sn FGL174111LW
hw-module pvdm 0/0
hw-module sm 1
redundancy
ip ftp source-interface GigabitEthernet0/0.10
ip ftp username anonymous
ip ftp password config
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 ip address 10.1.1.2 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/0.5
 encapsulation dot1Q 5
 ip address 10.1.5.1 255.255.255.0
 encapsulation dot1Q 10
 ip address 10.1.10.254 255.255.255.0
 ip helper-address 10.1.5.2
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface SM1/0
 ip address 10.1.20.1 255.255.255.0
 service-module fail-open
 service-module ip address 10.1.20.2 255.255.255.0
 service-module ip default-gateway 10.1.20.1
interface SM1/1
 description Internal switch interface connected to Service Module
 no ip address
interface Vlan1
 no ip address
router ospf 1
 network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 10.1.1.253 255.255.255.255 SM1/0
ip route 10.1.20.2 255.255.255.255 SM1/0
control-plane
mgcp profile default
gatekeeper
 shutdown
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
R1#sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 13:06 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
R1 uptime is 1 hour, 4 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 475136K/49152K bytes of memory.
Processor board ID FGL174111LW
4 Gigabit Ethernet interfaces
2 terminal lines
1 Channelized (E1 or T1)/PRI port
1 Virtual Private Network (VPN) Module
1 Services Module (SM) with Services Ready Engine (SRE)
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FGL174111LW
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          None          None           None
R1# sh inventory
NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: FGL174111LW, Hw Revision: 1.0"
PID: CISCO2911/K9      , VID: V07 , SN: FGL174111LW
NAME: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-1MFT-T1/E1  , VID: V01 , SN: FOC16345L87
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC173367QG
NAME: "Services Module with Services Ready Engine on Slot 1", DESCR: "Services Module with Services Ready Engine"
PID: SM-SRE-900-K9     , VID: V03 , SN: FOC15073WX2
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V05 , SN: DCA1730R1A7
Router Configuration......................
R1#sh
*Apr  7 05:24:37.163: %SM_INSTALL-6-INST_RBIP: SM1/0 received msg: RBIP Registration Requestrun
Current configuration : 1977 bytes
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
hw-module pvdm 0/0
hw-module sm 1
redundancy
interface Loopback0
 ip address 10.1.6.1 255.255.255.0
 no ip address
 shutdown
 no ip address
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
interface SM1/0
 ip unnumbered Loopback0
 service-module ip address 10.1.6.2 255.255.255.0
 service-module ip default-gateway 10.1.6.1
interface SM1/1
 no ip address
interface Vlan1
 no ip address
no ip http server
ip route 10.1.6.2 255.255.255.255 SM1/0
control-plane
gatekeeper
 shutdown
line con 0
line aux 0
line 2
 no exec
 stopbits 1
line 67
 no exec
 transport input all
 stopbits 1
line vty 0 4
 login
 transport input all
end
Please check my configuration....
R1#service-module sm 1/0 session
Trying 10.1.6.1, 2067 ... Open
Detect and Initialize network device
Backup current platform configurations....
SRE step 1 - SM registration...
Finding (hd1,3)/296e03bc-3236-4a68-a178-688e56400a1e, failed
Local install not supported
Response - no installation needed (len: 422)
SRE Installation Not Needed
Restoring original configuration...
Updating flash with bootloader configuration.
Please wait .................... done.
*Apr  7 05:26:08.143: %SM_INSTALL-6-INST_RBIP: SM1/0 received msg: RBIP Registration RequestLoading disk:/bzImage ... done.
Unable to load image
Error: Selected disk does not exist (21)
þnable to boot image
Initializing memory #1. Please wait...
Initializing memory #2. Please wait...
This may take a minute....
 Serial ATA Port 0 : Hitachi HTE545050B9A300
 Serial ATA Port 1 : Hitachi HTE545050B9A300
DDR Memory 4096 MB detected
Intel(R) Core(TM)2 Duo CPU     L9400  @ 1.86GHz
BIOS SM 3.52.8,  BIOS Build date: 02/08/2011
System now booting...
Please wait...
Please press P to select Primary Boot Loader ...
          or S to select Secondary Boot Loader ...
          or wait to boot from default configuration ...
SRE module get located and run....
Now booting from secondary boot loader....
Authenticating boot loader....
Secondary Boot Loader authenticated - booting....
Please enter '***' to change boot configuration:
 ServicesEngine Bootloader Version : 2.1.37
ServicesEngine boot-loader>
ServicesEngine boot-loader> config
IP Address [10.1.6.2] >
Subnet mask [255.255.255.0] >
TFTP server [10.1.20.10] >
Gateway [10.1.20.10] >
Default Helper-file [sre-v-installer.SPA.smv.2.0.1] >
Ethernet interface[external|internal] [internal] >
Default Boot [none|disk|diag|chainloader] [disk] >
Default bootloader [primary|secondary] [secondary] >
please help me...............................................
561
