Suse Linux loses SAN connectivity
Hi All,
anyone come across a problem before where a blade with Suse/Redhat linux installed loses connectivity when one of the HBA is disconnected? we have a situation where we have a blade with Suse linux 11 installed (SAN boot) & we configured 2 vHBA's (one on each Fabric) plus Powerpath is installed & configured correctly (as advised by SAN vendor).
we "disabled" one of the vHBA's & immediately we lost connectitity even though the 2nd vHBA was still "connected". as soon as we re-enabled the vHBA, it started working. we then tested by disabling the 2nd vHBA & left the 1st vHBA running & it still lost connectivity.
we will be looking at the powerpath logs, but i thought i would ask the forum to see if anyone can give some pointers,
any suggestions?
Kassim
Kassim,
How exactly are you "disabling" one of the vHBAs?
Robert
Hi Robert,
i "disabling" the vHBA's by changing its VSAN to default from the correctly configured one.
Kassim
Good deal - thats the preferred method.
Do you notice the issue with powerpath not installed?
Rob
Robert,
have not tested without powerpath but i guess it will be the same.
reason for saying the above is that we found out the problem yesterday when SAN vendor was carrying out a FLARE code upgrade on the SAN & when SPA rebooted, our Suse server fell over. all other ESXi hosts continued working.
we checked the powerpath install & found that it was installed but was not registered. below was the output when querying the powerpath install:
# rpm -qa EMCpower*
EMCpower.LINUX-5.3.2.00.00-029
# powermt check_registration
There are no license keys now registered.
# powermt display dev=all
PowerPath modules are not loaded.
Ensure that the modules are loaded and try again.
so i guess this "might" equate to powerpath not been installed as its un-usable.
we did get it registered & configured & asked SAN vendor to confirm the config & they were happy with it.
Kassim
If other hosts stayed (ESX) then this is not likely to be a UCS issue, but rather an OS/driver problem with SUSE.  I'll do some digging to see if we've seen any similar issues with SUSE 11.
Robert
Thanks Robert.
494
