UCS 2.0(1t) Firmware policy question
Anyone run in to an issue where after applying to 7 servers, the firmware policy won't apply anymore?  I can't hit the drop down menu for the firmware policy anymore.  even on the servers that HAVE the new policy.  It is greyed out.  Is there a limit or something?
I have a support call involved with this (technically I added this to the support call), but wouldn't mind any input
BTW - when I updated the USER information on the service profiles (ie annotating what host name was associated with the server) it rebooted the servers.  THAT has NEVER happened before....
Re: UCS 2.0(1t) Firmware policy question
Eric
Are you 100% sure that the firmware was updated on the system? If you expand out the hardware and check the running version versus the backup version you may see your issue of why you cannot apply the new firmware. Sounds like components are not fully updated.
100% sure. All the servers report the same 2.0(1t) Chad Austin is working
another issue regarding the update as well.
Eric Blecke
ECB Systems
443-252-4357
On Dec 28, 2011 8:25 PM, "rewilkin" <
548
