ucs 2.2(2c) upgrade
tried to upgrade infrastructure with auto update from 2.2.1b to 2.2.2c and it seems to have hung
can no longer get at ucsm
Faba webpage will not load (can ssh)
Fabric B webpage will load and bring up the java app - 2.2(2c) but get error
UCSM not available on secondary node
Everyone's tags (1)
1 REPLY
Hi,Connect through SSH and
Connect through SSH and run the command "show cluster extended" and share it here.
Also, without doing much troubleshooting (which is not my prefered way to go) you may try a clusted lead change witht he command  "cluster force primary" from the Fabric that responds but I would leave that as last resort.
You may try to ping the primary FI´s ip address and see if it responds.
I hope this helps,
-Kenny
22
