UCS 200 have CIMC issues shows address but does not respond to http requests
ryfoley
ok
i have 5  usc machines and doing the bios updates and CIMC updates  on 4 machine no issues . for some reason on the last machine it waned to be a pain .. i did the bios update just like all the other machines that are working and online ..  and then rebooted after that was complete i went into the CIMC console  web page of the system ( . like the other ones . went into the firmware management page . told the system to update the firmware . it took just the same amount of time as the other 4 machines . i watched it and it said complete with no issues .. .. so i told it to activate the new firmware that it downloaded to the system . and now it will not respond over IP anymore . not sure where to go and what to do next . do i need to call tech support and request a new machines ? .. is it dead ...
i have powered off the server . rebooted ....  and then booting up if does show that the CIMC does have an ipaddress on boot up . so i assume that it is working . i try and ping it from both my laptop and desktop . ( one wired and one wireless on different segments and they both respond but to no avail it still does not respond to http access ..
anyone have any ideas how to get it back online
thanks
ryan
31 Replies 31
ryfoley
is there any way to push the old firmware back to make it work again ?
command line interface . or something to allow me to do that .
I have the same problem is with C220 version1,5(4)
is this problem still not resolved,
is a reboot of the server the only possible solution in this?
Ad, so you can still ping your server but have no access to CIMC either SSH or Web? If so, there is this bug that talks about the issue https://tools.cisco.com/bugsearch/bug/CSCun88303/?reffering_site=dumpcr ; and as you can see the fix is in 2.0(3i ) and above (just released on March 13th)
If this answers your question, please mark it as such for future users to see you found the information you were looking for.
-Kenny
Looks like I've been bit by this bug.  One of my C240 M3 servers with 1.5(4) has increased fan speed, pings good to CIMC IP address, no access to web interface or SSH.
Step 11 of the process makes me nervous.  I assume there's no reason why I have to update the HDD firmware.  It seems that's a separate and optional step.  The previous steps in the directions appears to update the firmware of everything else, so if there's truly no requirement to update the HDD firmware, I'd just assume avoid doing it.   No need to tempt fate?  ;-)
Step 11:
If you want to update the firmware of the hard disk of a server, click Update HDD Firmware. A window displays a list
of hard disk drives on the server that support new firmware. Hard disk drives that do not support firmware upgrades are
not listed.
Updating the firmware of the hard disk drive could result in data loss. Cisco recommends that you take a
complete system backup prior to updating the firmware.
Important
a) To update the firmware of all the hard disks, click Update All.
With this option, HDDs with the latest firmware installed are not updated.
b) To update a specific HDD, choose the HDD and click Update.
So far, only reason why we upgrade disk drives is this :
http://www.cisco.com/c/en/us/support/docs/field-notices/638/fn63812.html
That's what I have at the top of my head, if you dont have Seagates, than I think you dont need to upgrade.
-Kenny
I saw your reply about the hard drives in my email but I don't see it here on the web page.  Strange.
Anyway, I decided to update the C240 M3 that is the standby (Update All, but not updating the HDD) because it has no phones or trunks registered to it and so far the process has been a nightmare.  First, it took forever to get Java to work for the virtual KVM.   I had to remove the latest version and install a version 7.  I spent most of my time just troubleshooting to see why Java wouldn't load the KVM.  Then, once I got the update going, I lost contact with the KVM as expected (says so in the HUU user guide, but it says I should be able to reconnect and continue the process)....but no matter what I tried, I could never get the remote KVM to load again.  I finally had get my local guy to plug in a monitor and keyboard to the back of the server.  The HUU was still up and the update status of the CIMC was failed.  I had him click Update All again to try it one more time.  Waiting to see what happens now.  This is extremely frustrating.
maybe Try old version of Java - java6
I was finally able to get it to work correctly with Java 7 update 21 on another machine.  After firmware version 2.0(3i) was installed on the CIMC, I can access the KVM with the latest Java version, which is great.  Java 8 update 45 works now.
ryfoley
please delete question as i figured out my own issue .
thanks
I'm seeing the same issue here.
We have two UCS C200M1 servers, both of which show a proper setup when going into the CIMC setup (press F8 at boot time), but yet, I can't connect to the management port with a browser.
Any pointers on what to check for ?
Thank you
Luc
Any fix?
I have 6 C210M2, 5 of them I can ssh/https to ip.
The trouble one I can ssh to, but no response on https. How do you restart the web server on the CIMC?
ucs-c2xx# show version
Firmware Version
1.3(1d)
ucs-c2xx#
ucs-c2xx# show http detail
HTTP Settings:
    HTTP Port: 80
    HTTPS Port: 443
    Timeout: 1800
    Max Sessions: 4
    Active Sessions: 0
    Enabled: yes
ucs-c2xx# show http
HTTP Port  HTTPS Port Timeout  Active Sessions Enabled
80         443        1800     0               yes
ucs-c2xx#
You can do the following via the SSH
01# scope http
01 /http # set enabled no
Warning: setting "enabled" to "no" will disconnect all
existing http connections and will disable login via WebUI.
01 /http *# commit
01 /http # set enabled yes
01 /http *# commit
01 /http #
./Abhinav
hmm... I can't seem to issue those commands. Is there a command I need to
put before entering: scope http?
Sorry, I'm a rookie when it comes to UCS (we just moved to UCS from
stand-alone, and a vendor set it all up)...
login as: root
root@10.0.20.101's password:
You have activated Tech Support Mode.
The time and date of this activation have been sent to the system logs.
VMware offers supported, powerful system administration tools. Please
see www.vmware.com/go/sysadmintools for details.
Tech Support Mode may be disabled by an administrative user.
Please consult the ESXi Configuration Guide for additional
important information.
~ # scope http
-ash: scope: not found
~ # scope https
Josh Gertig
Voice Communications Analyst - Team Lead
National Rural Utilities Cooperative Finance Corporation
(703) 467-1695 (direct)
(571) 455-9359 (cell)
(703) 467-8976 (fax)
Hi Joshua,
Looks like you SSHd' into the ESXi IP address and not the CIMC IP address, can you verify the IP.
./Abhinav
