UCS 6248UP to UCS 2104XP AND UCS 6120XP to UCS 2208XP
  1. Is the UCS 6248UP compatible with the UCS 2104XP? AND
  2. Is the UCS 6120XP compatible with the UCS 2208XP?
Thank you.
1 ACCEPTED SOLUTION
Hi Michael, The FI's paring
Hi Michael,
The FI's paring with the IOM's should not matter.
With 2208 the number for back plane ports increase to 32 , while they are 8 with 2104.
The only requirment is to have a  minimum software version of 2.0(1m)
Please refer the below link to confirm the same.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/OL_25363.html#pgfId-49903
Majid
1 REPLY
Hi Michael,
Majid
149
