UCS and Netapp ISCSI direct connect
I can't ping from ESXi ISCSI vmkernel to Netapp iscsi interface.
Can't see the provisioned storage on ESX.
I want to rule out any issues on the UCS side.
UCS 2.2.2 version with ESXi 5.5 local boot, loaded on the blades.
Netapp direct attached to UCS via ISCSI 10gb.
HLSRUCSFI-A(nxos)# sh mac address-table vlan 93
Legend:
        * - primary entry, G - Gateway MAC, (R) - Routed MAC, O - Overlay MAC
        age - seconds since last seen,+ - primary entry using vPC Peer-Link
   VLAN     MAC Address      Type      age     Secure NTFY   Ports/SWID.SSID.LID
* 93       0025.b50a.3208    static    0          F    F  Veth725
* 93       0025.b50a.321d    static    0          F    F  Veth709
* 93       0025.b50a.323a    static    0          F    F  Veth717
* 93       0025.b50a.323f    static    0          F    F  Veth701
* 93       0050.566b.9e8d    dynamic   10         F    F  Veth701 <--vNIC
* 93       00a0.981b.9dce    dynamic   10         F    F  Eth1/9 <--Netapp
~ # vmkping -I vmk2 10.50.93.101
PING 10.50.93.101 (10.50.93.101): 56 data bytes
--- 10.50.93.101 ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss
VIP Red
Is your Netapp in the same IP
Is your Netapp in the same IP subnet as the ESXi vmkernel interface ?
Is the Netapp hanging off a "Appliance" Fabric Interconnect port ?
I would also check, if your vlan 93 (for your vnic mapped to iscsi interface) is marked as native vlan !!!
Hello,Has the desired iscsi
Has the desired iscsi vlan been enabled on the standard uplinks as well as the upstream switch device? I have seen behavior where we are unable to start passing traffic to aplianes until we have hte vln configured there as well.
You will notice that the nic never actually pins to the appliance port, but instead pins to the uplink. The following whitepaper will go into more detail on that behavior:
http://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-6100-series-fabric-interconnects/whitepaper_c11-702584.html
-Gabriel
466
