UCS C-200 Sensor Error
I'm a newbie to UCS C series, customer has C-200 series servers. All are working fine customer just called and mentioned there was an Amber light in one of the servers. I checked the CIMC log here is the Waring and Critical error shown in the log
CRITICAL : FRU_RAM P3V_BAT_SCALED: Voltage sensor for FRU_RAM, failure event, Lower Critical going low (2.864 < 2.904 V) was asserted
Informational: LED_HLTH_STATUS: Platform sensor, AMBER was asserted
What should I do ? Is this just warning I need to call TAC to fix this.
Thanks for your help.
- Bala
Everyone's tags (2)
Bala,
The critical message is for CMOS battery voltage reading and we would need logs for further investigation.
Please open a TAC SR along with CIMC show tech log file
For a quick verification, we can execute the following commands in SSH session
scope sensor
show voltage
Padma
Thanks for the quick response Padma.
I already collected the show tech logs I will open a case with TAC. just FYI Here is the output of show voltage
ucs-c2xx-m2# scope sensor
ucs-c2xx-m2 /sensor # show voltage
Name                      Sensor Status  Reading    Units      Min. Warning Max. Warning Min. Failure Max. Failure
P3V_BAT_SCALED            Critical       2.864      V          N/A          N/A          2.904        3.168
P12V_SCALED               Normal         12.095     V          N/A          N/A          11.033       12.921
P5V_SCALED                Normal         4.989      V          N/A          N/A          4.844        5.157
P3V3_SCALED               Normal         3.302      V          N/A          N/A          3.192        3.381
P5V_STBY_SCALED           Normal         4.989      V          N/A          N/A          4.844        5.157
PV_VCCP_CPU1              Normal         1.196      V          N/A          N/A          0.725        1.392
PV_VCCP_CPU2              Normal         0.941      V          N/A          N/A          0.725        1.392
P1V5_DDR3_CPU1            Normal         1.499      V          N/A          N/A          1.431        1.558
P1V5_DDR3_CPU2            Normal         1.499      V          N/A          N/A          1.431        1.558
P1V1_IOH                  Normal         1.088      V          N/A          N/A          1.068        1.137
P1V8_AUX                  Normal         1.784      V          N/A          N/A          1.744        1.852
PSU1_VOUT                 Normal         12.000     V          N/A          N/A          N/A          13.000
PSU2_VOUT                 Normal         12.000     V          N/A          N/A          N/A          13.000
BTW, It is not related to this issue I tried to change the timezone using command line options but couldn't find those commands mentioned in the doc, CIMC version is 1.4. Is it not available because it is C-200 ?
Re: UCS C-200 Sensor Error
Just an update error was related to this bug CSCtr80666..fix was to update the CIMC firmware to 1.4.2.
Bala,
"" P3V_BAT_SCALED: Voltage sensor for FRU_RAM, failure event, Lower Critical going low (2.864 < 2.904 V) was asserted ""
The error message reports that CMOS battery voltage reading is less than the defined lower critical voltage value in the CIMC.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtr80666
The defect applies to scenarios where CIMC had incorrect threshold value for upper critical voltage and the reported value exceeds the defined value. In later releases, we increased the upper critical threshold value.
What version of CIMC do you have on C200 server ?
Padma
Padma,
Here is the BIOS version C200.1.4.1.0 (Build Date: 07/13/2011).
Thanks again for the followup.
Balu,
I would like to correct myself. We also lowered the lower critical ( LC - 2.345 ) and lower non-recoverable ( LNR - 2.178 ) threshold values too with this defect
So upgrading the firmware should resolve this alert.
Padma
5657
