08-20-2012 07:08 AM - edited 03-01-2019 10:34 AM
During the installation of a LSI 6G MegaRAID 9260-4i, I'm prompted with the statements "The battery is missing" and "Protect against data loss in the event of a server or power failure by providing emergency power to the cache memory."
Can anyone tell me if the battery back-up (R2XX-LBBU) for the LSI 6G MegaRAID 9260-4i (R200-PL004) is required or just simply a recommendation to prevent loss of data during a power failure? The ordering guide says "Battery Back-Up Option Available" so I'm assuming this is not a mandatory item for purchase.
Please advise.
C
Solved! Go to Solution.
08-20-2012 09:01 AM
Hello Chad,
BBU is optional.
C200 M2 technical spec sheet
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10493/c200m2_lff_specsheet.pdf
Please check out STEP 4 section.
Padma
08-20-2012 09:01 AM
Hello Chad,
BBU is optional.
Padma
