UCS C210M2 - Server not booting after CIMC firmware upgrade
After upgrading CIMC to 1.2(1a) firmware, server is not booting. Stops at "... checking hardware" and restarts itself. What can be done? Can I connect to serial console (need serial cable pinout) and boot CIMC with the backup firmware?
Re: UCS C210M2 - Server not booting after CIMC firmware upgrade
Zeljko -
If the server is not getting passed the memory tests/hardware self checks, this sounds like a hardware issue, or a corrupt firmware version.  You might want to contact Cisco TAC to get this investigated further.
Jen
Jen,
That is exactly what I did. They are sending replacement.
Thanks for taking time to help,
Zeljko
783
