UCS C220 M3 FlexFlash warning
We have UCS C220 M3 hosting Unified Comminications application CUCM CUC IM&P UCCX.
In CICM / Storage : Cisco FlexFlash appears with a warning "Raid Degraded" because there is only one SD card provided by default in the server. We have no use of it and it is in state "Disconnected".
Q: Is it possible to disable this warning
1 ACCEPTED SOLUTION
Hi Rich,
Do you have the OS installed on the SD card? If you do you will have to install the second SD card and sycn the hypervisor partition.  If you are not using the SD card and you want to get rid of this message you will have to remove the SD card from the server and reboot the CIMC (See release notes below).
Cisco Flexible Flash Controller
http://www.cisco.com/en/US/docs/unified_computing/ucs/release/notes/OL-28995-01.html
Hi Rich,
Hi Manuel,
Thank you for your answer.
Nothing installed on the SD card.  ESXi installed on the Raid5 array.
Kind Regards
590
