11-12-2013 07:05 PM - edited 03-01-2019 11:21 AM
I have a UCS C220 M3S running BIOS 1.5.1g and CIMC fireware 1.5(1l).There is a LSI MegaRAID SAS 9266-8i(Fireware 23.9.0-0023)controller with TMM-C Super-Cap inside.
CIMC appear that overall storage status:severe fault and the controller information,physical information,virtual drive information,BBU all have severe fault state.
How to solve this problem?
Solved! Go to Solution.
11-12-2013 08:56 PM
Mei Na,
The server is losing connection to the RAID controller and it is very likely that it needs replacement, please open a TAC case for confirmation and appropiate replacement if the issue is confirmed by a TAC engineer.
rate ALL helpful answers.
-Kenny
11-12-2013 09:32 PM
Mei Na,
Go to Cisco.com and place the arrow on "Support" (dont click on it) , then "New Case" and lastly, follow the wizerd, check it out:
Good Luck!
-Kenny
11-12-2013 08:56 PM
Mei Na,
-Kenny
11-12-2013 09:12 PM
Hi,keny
Thank you foy your answer,but how can i contact TAC engineer to confirm this situation?
mei na
11-12-2013 09:32 PM
Mei Na,
Good Luck!
-Kenny
