UCS-C220M3- PXE-E61: Media test failure, check cable
Dear All,
I have UCS-C220M3 server i am planning to install VWLC(Vertual Wireless lan controller ) and Cisco Prime i coonected power ,put the hard disk after i start UCS but it showing  PXE-E61: Media test failure, check cable  this error
this my 1st UCS work anybody can help me how to configure UCS-C220M3 rack mount server i have two vmVMware vSphere licence
how to i can install and configure  WLC and Cisco prime in UCS-C220M3 server
Could you please help me...
I am waiting for your valuable replay
Muhammed
  • Unified Computing
1 REPLY
Hello Muhammed,
""  PXE-E61: Media test failure, check cable  "'
Above message says you have enabled LAN / PXE boot in boot order but have not connected physical cable to LOM NIC ports.
To achieve your goal of deploying vWLC and Prime VMs, you first need to start with configuring CIMC.
Once you can reach CIMC over the network, you can use KVM and install the ESXi.
After installing ESxi, you need to follow the installation docs of vWLC and Prime.
Padma
1029
