UCS Central 1.1.2a Lic Problem
Stefan Gruber
Hello
i create a UCS Central free lic with the GUID and downloade the lic file to my PC.
Than I would Uploade the File to the UCS Central Licening Center an I get the Error
That the File already  exist
But this is a new Installation and i don't see any installed lics?!
10 Replies 10
Walter Dey
Recommended version is 1.2.1d ?
have a look at this recent post
https://supportforums.cisco.com/discussion/12329936/no-5-free-domain-after-ucs-central-121a-activation
Hello and thx for u answer
now i have upgrade to 1.2.1d
And i have always the same Problem.
If i would upload the lic file i get the error that the same doc with the same Name already exist.
Since the Installation 125 days are left
See the screenshots above
Here my lic infos
UCS-Central(service-reg) /license # show usage detail
License instance: UCS_CENTRAL_ACTIVATION_PKG
    Scope: Server
    Default: 5
    Total Quant: 5
    Used Quant: 0
    State: License Ok
    Peer Count Comparison: No Peer
    Grace Used: 0
License instance: UCS_CENTRAL_DOMAIN_REGN_PKG
    Scope: Server
    Default: 5
    Total Quant: 5
    Used Quant: 1
    State: License Graceperiod
    Grace Used: 507600
Can someone help me?
Which license did you request: initial license use the license code L-UCS-CTR-INI=.
This is the license for the first 5 domains and is 0$.
For domains >5 you need domain licenses use the license code L-UCS-CTR-LIC=.
Hi  i have this
Product Name: L-UCS-CTR-INI=
Product Description: UCS Central Initial Activation for 5 UCS Domains
Entitlement Qty: 1
Than i made with the PAK and the GUID from my UCS Central the lic file Online.
Downlode and unpack it.
now i have this file: UCSCENTRALFEAT2014xxxxxxxxxxx.lic
And i can't uplode it!
Ok, you did everything correctly.
Can you change the name of the file, and try again.
Or deregister your UCS domain, and start from scratch ?
thx for help
i have Change the Name: same Problem
I have Change Group Assigment to the "Domain Group root"  in UCS C: same Problem
I have "unregister"  from UCS Central in UCS Manager after Change Group " Assignment back to "unregistered" in UCS C: Same Problem
I think the Problem is thats "grace Period Used: 5 Days??
Could this be the cause of the trouble
Deleting
a
license
from
Cisco
UCS
Central
removes
only
the
license
file
from
the
system.
If
you
try
to
download
the
same
license
after
deleting
it
from
the
system,
you
might
encounter
a
download
license
error
So
when
you
delete
a
license,
you
must
delete
the
associated
download
task
for
that
Deleting
a
license
from
Cisco
UCS
Central
removes
only
the
license
file
from
the
system.
If
you
try
to
download
the
same
license
after
deleting
it
from
the
system,
you
might
encounter
a
download
license
error
So
when
you
delete
a
license,
you
must
delete
the
associated
download
task
for
that
Deleting
a
license
from
Cisco
UCS
Central
removes
only
the
license
file
from
the
system.
If
you
try
to
download
the
same
license
after
deleting
it
from
the
system,
you
might
encounter
a
download
license
error
So
when
you
delete
a
license,
you
must
delete
the
associated
download
task
for
that
Deleting a license from Cisco UCS Central removes only the license file from the system.
If you try to download the same license after deleting it from the system, you might encounter a download license error.
So when you delete a license, you must delete the associated download task for that license
Hello and thx
i see this too,
but if u see  the second and the third pic in my first post, u can see that i don't have any downloade Tasks or lic's  in the UCS Central.
This is the first time if i would to uploade a lic, I have never delet a lic!
Hi Steve !
Reboot your VM, and if this doesn't fix the issue, open a TAC case.
Walter.
Hi i have reboot twice  today for the Upgrade to 1.2.1d
