03-07-2014 07:26 AM - edited 03-01-2019 11:34 AM
All of my fans in my UCS chassis are being flagged as inoperable?
The fans are screaming in the datacenter. Very loud. Room temp is fine.
Lots of errors like this?
<faultInst
ack="yes"
cause="equipment-inoperable"
changeSet=""
code="F0373"
created="2014-03-06T21:46:44"
descr="Fan 1 in Fan Module 1-1 under chassis 1 operability: inoperable"
dn="sys/chassis-1/fan-module-1-1/fan-1/fault-F0373"
highestSeverity="major"
id="520430"
lastTransition="2014-03-06T21:46:44"
lc=""
occur="1"
origSeverity="major"
prevSeverity="major"
rule="equipment-fan-inoperable"
severity="major"
status="created"
tags="network,server"
type="equipment">
</faultInst>
Solved! Go to Solution.
03-07-2014 09:05 AM
Steven,
See this:
There is primarily a communication error (not a hardware failure,at least at first glance) with IOM attached to FI-B. Look at the difference between both of the IOMs, where the IOM to FI-A is affected but not that much (I made it a little more understandable):
DC-UCS-FI-A# connect iom 1
fex-1# show platform soft cmc showi2c
segment 1 chassis
norxack 5514 <<<<< means a problem if you have this much
unfinished 1
lostarbitration 1
fixup 2
segment 2 blade
segment 3 fan
segment 4 psu
pca9541postio2 12
gilroy.error.pca9541_control_state 77
gilroy.error.do_reserve_pca9541_control 77
bus_lost_counter: 991
error_pca9541_per_device:
c.ms 77 <<<< This is a problem with the chassis management selector which is located on both IOMs for mgnt
c.gpio0 1
# I2C Device Statistics
c.seeprom={SUCCESS=262839}
f.fm0.fru={SUCCESS=1} <<<<<< All fans are talking fine with the IOM that is supposed to manage their behavior
f.fm1.fru={SUCCESS=1}
f.fm2.fru={SUCCESS=1}
f.fm3.fru={SUCCESS=1}
f.fm4.fru={SUCCESS=1}
f.fm5.fru={SUCCESS=1}
f.fm6.fru={SUCCESS=1}
f.fm7.fru={SUCCESS=1}
DC-UCS-FI-B# connect iom 1
segment 1 chassis
norxack 2795 <<<<<<<
wait_gt_deadline 207743
segment 2 blade
segment 3 fan
norxack 108550 <<<<<< Is evident the problem when talking to the other IOM
timeout 27815 <<<<<<
unfinished 14
fixup 55614
pca9541clrerrprs 7
pca9541seterr 2
pca9541postio3 2
wait_gt_deadline 9319746
hub_sw_mbb 27785
hub_sw_mbb_to 27785
segment 4 psu
pca9541postio2 12
wait_gt_deadline 6664338
gilroy.error.pca9541_control_state 99
gilroy.error.do_reserve_pca9541_control 99
bus_lost_counter: 535
c.ms 99 <<<<< c.ms again
f.fm0.fc 3 << and the fans showing up here
f.fm1.ms 1
f.fm2.ms 1
f.fm3.fc 2
f.fm3.ms 1
f.fm4.ms 1
f.fm5.ms 1
f.fm6.ms 1
f.fm7.ms 1
c.seeprom={SUCCESS=263768}
f.fm0.fc={SUCCESS=4410402,EIO=2,EBUSY=3477} << this means an efforts to communicate but finds the channel busy
f.fm1.fc={SUCCESS=4407270,ENXIO=2,EBUSY=3478}
f.fm2.fc={SUCCESS=4406286,EBUSY=3478}
f.fm3.fc={SUCCESS=4406492,ENXIO=2,EBUSY=3476}
f.fm4.fc={SUCCESS=4406621,EBUSY=3476}
f.fm5.fc={SUCCESS=4407430,EIO=1,ENXIO=1,EBUSY=3476}
f.fm6.fc={SUCCESS=4407772,EBUSY=3476}
f.fm7.fc={SUCCESS=4407739,ENXIO=1,EBUSY=3480}
I would recommend to reseat the IOM connected to FI-B during a maintenance (take out for about 5 minutes to drain all the power), same as the fans (take the fans out for about 3 minutes, same reason as the IOM) and be sure you are running the follwoing versions or above, according to the firmware you are running: 2.0.5b or later OR 2.1.1f or later OR any version of 2.2. IF you are already running one of those versions, then just do the reseat.
I hope this helps.
Rate ALL helpful answers.
-Kenny
03-07-2014 08:09 AM
Hello Steven,
Are these messages transient? I mean, are they also cleared within minutes or the issue keeps on showing in UCSM and nothing clears the iisue?
Could you please run the following command and paste the output?
Connect local a
connect iom X <<< X is the chassis number with the issue
show platform soft cmc showi2c \no-more
exit
Connect local b
show platform soft cmc showi2c |no-more
-Kenny
03-07-2014 08:40 AM
Attaching to FEX 1 ...
To exit type 'exit', to abort type '$.'
fex-1#
# I2C Bus Statistics Fri Mar 7 10:38:23 CST 2014
# I2C Bus 1
busn=0 nseg=2
segment 0 local
segment 1 extended
wait_gt_deadline 1102083
# I2C Bus 2
busn=1 nseg=5
segment 0 local
segment 1 chassis
norxack 5514
unfinished 1
lostarbitration 1
fixup 2
pca9541seterr 1
wait_gt_deadline 437329
segment 2 blade
segment 3 fan
segment 4 psu
pca9541postio2 12
gilroy.counter.reserve 74
gilroy.counter.release 3
gilroy.counter.reserved 9277908
gilroy.counter.already_reserved 1
gilroy.counter.released 9277136
gilroy.counter.already_released 770
gilroy.counter.status_chassis_off 16828076
c.ms 77
c.gpio0 1
iom.fru={SUCCESS=12}
iom.rtc={SUCCESS=7}
NAME=iom.woodside
No such path /sys/devices/platform/fsl-i2c.1/i2c-0/0-0048
NAME=iom.dcdc0
detach_state driver iout iout_cal_offset iout_oc_fault_limit mfr_date mfr_id mfr_location mfr_model mfr_revision mfr_serial name ot_fault_limit ot_warn_limit temperature1 temperature2 vin vin_ov_fault_limit vin_uv_fault_limit vout vout_mode vout_n vout_ov_fault_limit vout_uv_fault_limit
NAME=iom.dcdc1
iom.gpio0={SUCCESS=984572}
iom.gpio1={SUCCESS=984572}
iom.gpio2={SUCCESS=984572}
iom.gpio3={SUCCESS=1969208}
iom.temp.inlet1={SUCCESS=3937667}
iom.temp.inlet2={SUCCESS=3937667}
iom.temp.woodside={SUCCESS=3445459}
c.fru={SUCCESS=2}
p.psu0.fru={SUCCESS=1}
p.psu1.fru={SUCCESS=1}
p.psu2.fru={SUCCESS=1}
p.psu3.fru={SUCCESS=1}
c.gpio0={EIO=1,ENXIO=7}
c.gpio1={ENXIO=8}
c.gpio2={ENXIO=8}
c.gpio3={ENXIO=8}
# I2C Driver sysctl entries
sysctl: error: permission denied on key 'net.ipv4.route.flush'
sysctl: error: permission denied on key 'kernel.cad_pid'
sysctl: error: permission denied on key 'kernel.cap-bound'
dev.i2c.disconnect_retry = 3
dev.i2c.post_trigger = 64
dev.i2c.norxack_blink = 5
dev.i2c.fixup_blink = 0
dev.i2c.pca9541-workaround = 16
dev.i2c.wait_deadline = 30
dev.i2c.chassis_reservation.demand = 0
dev.i2c.chassis_reservation.lock_state = 1
dev.i2c.chassis_reservation.auto_release = 1
dev.i2c.chassis_reservation.on_demand = 0
dev.i2c.chassis_reservation.pause_gilroy_thread = 0
dev.i2c.chassis_reservation.min_notheld_ms = 150
dev.i2c.chassis_reservation.wait_extra_ms = 2000
dev.i2c.chassis_reservation.grace_ms = 500
dev.i2c.chassis_reservation.hold_ms = 1000
dev.i2c.chassis_reservation.wait_ms = 1500
dev.i2c.gilroy-debug-level = 3
dev.i2c.debug-level = 1
dev.i2c.pca9541-businit = 1
dev.i2c.pca9541-delay = 250
dev.i2c.bus2.write-cdelay = 100
dev.i2c.bus2.write-delay = 100
dev.i2c.bus1.write-cdelay = 30
dev.i2c.bus1.write-delay = 30
fex-1#
# I2C Bus Statistics Fri Mar 7 10:39:32 CST 2014
# I2C Bus 1
busn=0 nseg=2
segment 0 local
wait_gt_deadline 4
segment 1 extended
wait_gt_deadline 670925
# I2C Bus 2
busn=1 nseg=5
segment 0 local
segment 1 chassis
norxack 2795
segment 2 blade
segment 3 fan
norxack 108550
timeout 27815
unfinished 14
fixup 55614
pca9541clrerrprs 7
pca9541seterr 2
pca9541postio3 2
hub_sw_mbb 27785
hub_sw_mbb_to 27785
segment 4 psu
pca9541postio2 12
gilroy.counter.reserve 50
gilroy.counter.release 49
gilroy.counter.reserved 9277823
gilroy.counter.already_reserved 2
gilroy.counter.released 9259317
gilroy.counter.already_released 18459
gilroy.counter.status_chassis_off 12692228
c.ms 99
f.fm0.fc 3
f.fm1.ms 1
f.fm2.ms 1
f.fm3.fc 2
f.fm3.ms 1
f.fm4.ms 1
f.fm5.ms 1
f.fm6.ms 1
f.fm7.ms 1
iom.rtc={SUCCESS=7}
NAME=iom.woodside
NAME=iom.dcdc0
NAME=iom.dcdc1
iom.gpio0={SUCCESS=922122}
iom.gpio1={SUCCESS=922137}
iom.gpio2={SUCCESS=922122}
iom.gpio3={SUCCESS=1844308}
iom.temp.inlet1={SUCCESS=3687803}
iom.temp.inlet2={SUCCESS=3687803}
iom.temp.woodside={SUCCESS=3226828}
c.fru={SUCCESS=2}
p.psu3.psmi={SUCCESS=12974716}
p.psu0.psmi={SUCCESS=13299601}
p.psu1.psmi={SUCCESS=12974803}
p.psu2.psmi={SUCCESS=12974774}
c.gpio0={ENXIO=8}
c.gpio1={ENXIO=8}
c.gpio2={ENXIO=8}
c.gpio3={ENXIO=8}
fex-1#
03-07-2014 09:05 AM
Steven,
See this:
segment 1 chassis
unfinished 1
lostarbitration 1
fixup 2
segment 2 blade
segment 3 fan
segment 4 psu
pca9541postio2 12
c.gpio0 1
segment 1 chassis
segment 2 blade
segment 3 fan
unfinished 14
fixup 55614
pca9541clrerrprs 7
pca9541seterr 2
pca9541postio3 2
hub_sw_mbb 27785
hub_sw_mbb_to 27785
segment 4 psu
pca9541postio2 12
f.fm1.ms 1
f.fm2.ms 1
f.fm3.fc 2
f.fm3.ms 1
f.fm4.ms 1
f.fm5.ms 1
f.fm6.ms 1
f.fm7.ms 1
I hope this helps.
-Kenny
03-07-2014 09:50 AM
Running 2.1(3a)
We dont have a maintenance window per say. So can this be done while production is running? Removing one IOM should be ok since the traffic will take the path of the other IOM correct?
03-07-2014 09:54 AM
If you are sure it is properly configure in the Service Profile then that is true...for ethernet traffic.... for FC traffic you need to configure multipath at the OS level...
Or if you are using vCenter, Nexus1000v can also take care of it for you.
-Kenny
03-07-2014 10:30 AM
Most blades are using ESXi so multipath is enabled and working. The other blades are using Linux on baremetal and fabric failover is configured so I assume I am good.
03-07-2014 11:09 AM
Cool, if this solves the issue don't forget to mark the question as answered. In the other hand, if the issue is not solved, open a TAC as you might need to have someone checked the hardware as there are some hardware fixes that can help solve the situation and further investigate if there is anything else.
-Kenny
03-07-2014 11:27 AM
starting with the least risky process, I reseated every fan within the chassis and all events have been cleared.
Thanks Keny!
03-07-2014 11:34 AM
Glad I helped
