UCS (DCUCD) Question
please help me these are quite confused.........Please help me
1>Data center analysis tools are most useful for which two purposes?(Choose two.)
A. network device discovery
B. capacity plan optimization
C. network performance management
D. determine server adapter choice(NIC,HBA or CNA)
E. determine server utilization and workload assessment
2>What two items are considered when assessing storage performance?(Choose two)
A. SAN throughput
B. number of VSANs
C. number of SAN Domains
D. maximum number of LUNS
3> What are three types of business pressure that data centers are experiencing?(Choose three)
A. language barrier
B. collaboration
C. SLA metrics
D. global availability
E. separate infrastructures and support organizations
4> Which two steps are considered when addressing environmental aspects of a proposed Data
     Center solution?(Choose two.)
A. Determine the type of firewall to be implemented
B. Identify physical access requirements for the facility
C. Determine operating parameters of the equipment.
D. Assess the environmental parameters of the facility
5> Which two design considerations are most often used when depIoying Virtual Machines on the
Cisco Sytems Nexus 1000V?(Choose two.)
A. VSANs to be supported must be configured in the Fabric Manager on the MDS switches
B. The defauIt VSAN is preconfigured in the Cisco UCS manager.
C. The defauIt VSAN is chosen as the defauIt connectivity for all vNlCs
D. AII VSANs In heterogeneous fabrics are used internaIly by the Cisco UCS system
6> Which two design considerations are most often used when depIoying Vinual Machines on the
Cisco Systems Nexus 1000V? (Choose two.)
A. data VSANs
B. management VLANs
C. port profile policy
D. uplink port profile
7>Which environmental parameters should be used when the parameters differ between equipment
in the solution?
A. the Ieast common denominator
B. use arrange from Ieast restrictive to most restrictive
C. the highest denominator from a single piece of equipment
D. the parameters from the most restrictive piece of equipment
E. the parameters from the Ieast restrictive piece of equipment
8>When a Unified fabric is depIoyed, what will be reduced?
A. cable overhead
B. computing utilization
C. provisioning complexity
D. seamless service deployment
9>Implementing the Cisco UCS would provide which benefit?
A. Application Mobility
B. decreased Storage Access
C. Data Consolidated Management
Re: UCS (DCUCD) Question
Hi robert
Thank you very much for your rply.
As per my study I have all the answers but those answer are little bit
confused with another options.That's why I ask for help to you.
Thanks again
TA
On Wed, Feb 15, 2012 at 10:15 PM, roberbur <
Hi Robert
  • My answer is like this is there any wrong answer?Please
help me if possible for you.*
A. SAN throughput
B. collaboration
C. SLA metrics
of a proposed Data
B. management VLANs
6>Which environmental parameters should be used when the parameters
in the solution?
7>When a Unified fabric is depIoyed, what will be reduced?
8>Implementing the Cisco UCS would provide which benefit?
With Regards
Tanmay
409
