UCS Dis-jointed L2 Domain and overlapping VLAN 1
I just deployed a UCS environment where we needed to configure dis-jointed L2 domains. The L2 domains have different VLANs and uplink port channel on each FI. I used VLAN Groups to map VLANs to their appropriate uplink port channels.
Everything is working as expected but there are these hidden faults that can only be viewed by selecting the show all option in the fault log.vlans.JPG
I can see from NX-OS that the only overlapping VLAN is VLAN 1
Po10          1,5,99-101,400,700,802,806,809,814,818,990
Po12          1,103-106,150
interface port-channel10
  description U: Uplink
  switchport mode trunk
  pinning border
  switchport trunk allowed vlan 1,5,99-101,400,700,802,806,809,814,818,990
  speed 10000
interface port-channel12
  pinning border
  switchport trunk allowed vlan 1,103-106,150
  speed 10000
Is there any way to remove VLAN 1 from the allowed vlan list?
1 REPLY
What is the firmware version running?
Did that start to happen after an upgrade?
What is the native vlan?
You could be hitting this defect:
https://tools.cisco.com/bugsearch/bug/CSCuh76091
CSCuh76091 - VLAN 1 always listed as overlapping in disjoint L2 setup
Symptom:
During the configuration of a disjoint L2 topology you'll get the following error message:
"Port: 1/11 following overlapping VLANs detected: 1"
Conditions:
Disjoint L2 setup and default vlan 1.
Workaround:
N/A.
Setting  the vlan you allowed on the separate uplink as "native" still results  in vlan 1 being added to the interface configuration.
More Info:
On this defect, the issue is cosmetic.
1861
