UCS equpiment serial nbrs
ron_hawkins
Has anyone developed any scripts or ? that can extract the serial numbers of their UCS equipment? For the life of me I can't understand why the blade export utility doesn't include serial number.
We're not using UCS Central yet.
Any help appreciated.
thanks.
Walter Dey
My favorite CLI commands are (putty session to fabric interconnect required)
"show Fabric-interconnect inventory expand" ===> Fabric Interconnect, Expansion Modules, Fans and PSUs
"show chassis inventory expand" ===>  Chassis, IOM, PSU's and Servers
"show server inventory expand"  ===>    Servers and Adapters
5 Replies 5
Walter Dey
Kenny,
Thanks a lot! That worked great.
take care.
Just to add to the above you can use grep ,egrep etc to get exactly what you want. These are the options available to sort out the output
UCS# show chassis inventory expand detail |
begin    count    cut      egrep    end      exclude  grep     head     include  last     less     no-more  sort     tr       uniq     wc
If you want to use UCS Powertool you can use these commands below , i have given two examples to stdout in either text or csv format. Remove the Export to get output on term.
 PS C:\get-ucsblade | select Serial, Slotid, Model, Chassisid > Blade.txt
 PS C:\ Get-UcsChassis | select serial,id,dn | Export-Csv .\Chassis.csv
Example output:
Serial                           SlotId Model               ChassisId
QCIXXXXXXXX                           1 N20-B6620-1         1
QCIXXXXXXXX                           2 N20-B6620-1         1
QCIXXXXXXXX                           3 N20-B6620-1         1
QCIXXXXXXXX                           4 N20-B6620-1         1
QCIXXXXXXXX                           5 N20-B6620-1         1
QCIXXXXXXXX                           6 N20-B6620-1         1
QCIXXXXXXXX                           7 N20-B6620-1         1
QCIXXXXXXXX                           8 N20-B6620-1         1
Thanks. The egrep method works for what I need but you piqued my interest in powertool:)
thanks.
Keny Perez
Level 8
Level 8
Ron,
Please delete this other duplicate thread https://supportforums.cisco.com/discussion/12139456/ucs-equpiment-serial-nbrs
-Kenny
