UCS Fabric Interconnect-switch mode
Can I connect my old HP server with DAS(to be used as a backup server) to a UCS FI operating in switch-mode-I guess I would need to connect the server to a network ports?
Rgds
Sumesh
Connecting 3rd party servers to the UCS FI is not a supported configuration.
Eric
As of UCSM version 2.0 you no longer need "switch mode" to directly connect storage devices.  You can set devices as Appliance ports.  There's a wealth of community posts on setting this up.  Pre 2.0 you would need switch mode, which gets really messy - you're far better directly connecting storage with Appliance ports on 2.0 or later.
As Eric mentioned, we only support Netapp & EMC devices for direct connect.
Please see the Storage Interop matrix for more detail.
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/interoperability/matrix/Matrix8.html#wp323848
That being said, it doesn't mean it will not work, just that TAC would not be able to assist if you ran into issues.
Robert
You just need Appliance Ports to connect a Server/NAS directly. Have connected a few 10G Microsoft Storage Servers for NAS storage via Appliance Ports.
Craig
My UCS Blog http://realworlducs.com
1156
