UCS Firmware Question
Hi:
Just want a definitive answer to the following question:
1. If my FInterconnect and IOM are having a "lower' firmware version than my UCS Blades (CIMC, BIOS & Adapter) assuning they are all at 1.4(3#) level, will the FI "upgrade" the firmwares on UCS Blade automatically?
2. If my FInterconnect and IOM are having a "higher' firmware version than my UCS Blades (CIMC, BIOS & Adapter) assuning they are all at 1.4(3#) level, will the FI "downgrade" the firmwares on UCS Blade automatically?
I remember someone from Cisco told me before that the downgrade or upgrade will happen automatically or I am wrong.
Thanks.
SiM
No, the only automatic firmware upgrade/downgrade is with the IOM modules. If you install a new chassis that has older/newer firmware than the Fabric Interconnects the IOM will be upgraded/downgraded to match.
Jeremy:
Greatly appreciated. I know some cisco folks are always there. i will try to remember that is only for IOM ny heart.
May I know what is the Correct Answer icon is for below the post?
SiM
Not sure what you are asking? Are you referring to the starts at the bottom?
Jeremy:
I mean this:
I can't open the image, looks like a broken link
Jeremy:
Just go to
https://supportforums.cisco.com/message/3599950
Look under yours or other replies to me. There is an icon called Correct Answer tab.
Sorry.
SiM
The Correct Answers icon is to highlight a response to a Post that was marked by the Poster as helpful.
We appreciate it when people respond to quesitons, that the person who posts the question (or even others) mark them with a star rating.
Robert
722
