Community Member
UCS Fusion IO installation on B200 M3
Does anyone have any Fusion/Cisco install documents?  Specicially for ESXi 5.1 U1.
1 ACCEPTED SOLUTION
Community Member
Hello Raphael,
Please find the below links for documents:-
http://www.fusionio.com/load/-media-/26jjt4/docsLibrary/Cisco_and_Fusion-io_VDI_whitepaper_C22-726648.pdf
http://www.fusionio.com/load/-media-/26n45g/docsLibrary/Cisco_UCS-Fusion-io-MS_SQL-Virtual_Performance_Cluster.pdf
https://www.fusionio.com/partners/Cisco
Hope it helps you.please let me know if need any more help on these.
Have i answered your query? if yes  then please make it answered.
Gaurav
Community Member
Hello Raphael,
Gaurav
Community Member
Hi Guys,
Im having a little trobule hear and wondered if you could possibly help me out.
I have followed the above links but am experiencing alerts in UCS Manager fromt the blades containing the Fusion IO cards. Each blade is displaying the following alert;
[FSM:FAILED]: sam:dme:ComputeBladeDiscover
Also, when I view the Fusion IO cards in the servers inventory the Controller Status is set to “Unknown”.
Did either of you experience a similar issue when you installed them?
Cheers
Alex
902
