UCS hardware recommendations
waqas gondal
I was looking for a recommendation of which parts I should be looking at for buying a UCS system to run just a few virtual machines and a catalyst switch that has the WLC capability. This is for a test environment to play around with ISE and Prime so additional machines might also get added to it.
However I will have to keep it relatively low cost for the business expense.
The things I will need are:
UCS blade - no idea which one to look at but the machines I will need on it at a minimum are ISE, Prime and a windows AD infrastructure with a CA server.
Catalyst 3650 for testing the functionality of ISE with the built in wireless capabilities of the switch.
Cheers,
Waqas
2 Accepted Solutions
Shahzad Arain
CISCO UCS B200 is good option to start with, for further details check below url.
http://www.cisco.com/c/en/us/products/servers-unified-computing/ucs-b-series-blade-servers/models-comparison.html
There are attractive UCS bundles, check eg.
https://apps.cisco.com/ccw/cpc/guest/home.do#!/content/ucsModelDetails/model_b200m3
UCS B200 M3 Entry SmartPlay Solution SingleConnect Solutions
Features 2x B200 M3 Blade Servers, 2x 6248UP Fabric Interconnects, and a Chassis.(UCS-SP7-B200-E)
MSRP from $26,898.14
Shahzad Arain
Following are ISE system requirements.
Platform
Processor
RAM
Hard disk
RAID
Ethernet NIC
Power
Cisco Identity Services Engine Appliance 3315 (Small)
1 x QuadCore
Intel Core 2 CPU Q9400
@ 2.66 GHz (4 total cores)
4 GB
2 x 250-GB SATA HDD
(250 GB total disk space)
No
4x Integrated Gigabit NICs
Cisco Identity Services Engine Appliance 3355 (Medium)
1 x QuadCore
Intel Xeon CPU E5504
@ 2.00 GHz (4 total cores)
4 GB
2 x 300-GB SAS drives
(600 GB total disk space)
Yes (RAID 0)
4 x Integrated Gigabit NICs
Redundant
Cisco Identity Services Engine Appliance 3395 (Large)
2 x QuadCore
@ 2.00 GHz (8 total cores)
4 GB
4 x 300-GB SFF SAS drives
Yes (RAID 0+1)
Redundant
Cisco Secure Network Server 3415 (Small/Medium)
1 x QuadCore
Intel Xeon CPU E5-2609
@ 2.40 GHz (4 total cores)
16GB
1 x 600-GB 10k SAS HDD
No
Cisco Secure Network Server 3495 (Large)
2 x QuadCore
@ 2.40 GHz (8 total cores)
32GB
2 x 600-GB 10k SAS HDDs
Yes (RAID 1)
Redundant
Shahzad Arain
Danny Sandner
If you want to use it just for a few VMs, UCS mini may be interesting for you :)
