07-19-2013 02:14 PM - edited 03-01-2019 11:08 AM
Is there any tools availble to gain KVM console access through IPMI for UCS Chassis blades? We would like to give group of users to access only KVM console of blades through IPMI tools and not through KVM console through UCS Mgr. This way, we don't have to create username at UCS Mgr level and thus prevent users to gain read only access to UCS MGR.
Thanks in advance for your help..
07-20-2013 03:31 AM
Hello Hetal,
I am not sure if I understood your requirement. KVM only access can be provided for IPMI user.
Check out method #1
https://supportforums.cisco.com/message/3394031#3394031
More detailed info
Padma
07-20-2013 08:57 AM
Padma,
Thanks for your quick response. Basically I am looking to get KVM access to Blades without using KVM Manager/method provided by Cisco UCS.
I am looking for some sort of third party IPMI tools Such as (VNC Viewer plus etc) to directly connect to blade using IPMI user credential.
Thanks again in advance for your help.
07-20-2013 09:00 AM
Hello Hetal,
In that scenario, I believe method 1 described in my previous post would meet your requirements.
Let us know if you have any issues with it.
Padma
