Bronze
UCS Manager Issue with 2.0(2q) and Java
Hey All,
I have done some reasearch and realize that we are far behind in our current UCS software but I am running into an issue.
In Jan/Feb we are supposed to do a major upgrade of both our UCS and CUCM\UC infrastructure at my job. In prep for that I need to get some info from UCS manager.
The problem is that when I try to connect to the UCS manager I get an error message, see image 1 below. In doing some reading I see the UCSM version we are running is not compatible with Java 7 so I also installed. Java 6 (, 2 different release) which you can see in image 2 below. In running either of those versions I get this issue.
Sort of a problem since I need info off the UCS to plan for the upgrade but can't get to it to get that info.
Anyone know of a specific Java version that will work with it?
IMAGE 1
IMAGE 2
1 REPLY
You need to totally uninstall Java 7 from your computer.
Java 6  must be 32bit.
352
