Community Member
UCS port-channel load-balancing algorithm
Hello
I am trying to investigate the packet flow through the UCS. Each Interconnect is connected with vPC to two Nexus 5000 switches. I would like to check which vPC interface will be used by the Interconnect to send the traffic to the other host.
I've checked the port-channel load balancing algorithm and it seems to be configured with "ip and mac address hash".
UCS-B(nxos)# sh port-channel load-balance
Port Channel Load-Balancing Configuration:
System: source-dest-ip
Port Channel Load-Balancing Addresses Used Per-Protocol:
Non-IP: source-dest-mac
IP: source-dest-ip source-dest-mac
When I tried to check the packet flow I received a following output
UCS-B(nxos)# show port-channel load-balance forwarding-path interface port-channel 10 src-ip 192.168.40.17 src-mac 0050.5688.05b3 dst-ip 192.168.40.19 dst-mac 0050.5688.17a9
Missing params will be substituted by 0's.
Load-balance Algorithm: source-dest-ip
crc8_hash: 77   Outgoing port id: Ethernet1/20
As you can see, both algorithms are not the same. The question is, which one will be used for the traffic living interconnect?
Thank you in advance for your answer
Lucas
1 REPLY
Community Member
Re: UCS port-channel load-balancing algorithm
One algorithm is for IP, another is for none-ip traffic?
2626
