Community Member
ucs sanboot - brocade switch cannot see the ucs blade wwn/wwpn
I have my brocade switch connected to my FIs, in the brocade switch I can see the FI WWN/wwpns. but When I power on a server, I cannot see th servers wwn/wwpn on the server
any idea?
I assume you have FI setup in
I assume you have FI setup in FC end host mode ? this is mandatory !!
Which OS do you have ? the Brocade has to be setup according to NPIV mode (they Access Gateway Mode)
Community Member
From the FI you can also do
From the FI you can also do the following to check if the FIs are "learning" the WWNs of the HBAs in question.
(nxos)# sho npv flogi-table
Don't forget to check your vsan settings.
137
