UCS Simulator Connectivity issue.
I 'm trying to use UCS simulator on my VMware workstation 7.1 The VA (virtual appliance) starts up fine and i can login with the given username and password and get the confiugration options. But when i try to connect to the simulator via GUI it does not work for me. And if i try to connect to the UCS ip on 80/443 port. Is there any setting which is need to be configured to make this work.
Thanks.
1 ACCEPTED SOLUTION
Yes that is the issue.  Login as config / config, and perform a factory reset.  This issue happens a low percentage of the time.  If you login and do a factory reset, it should fix it.
Eric
Did you provide IP's for all 3 NICs in UCSPE?  You didn't delete any of the three NIC's correct?  Generally on laptops / desktops I recommend you use NAT'ed NICs for all three.  Did you have that set as well?  Can you ping the addresses on your system?
Hi Eric,
I have all the 3 NICs set to NAT and they all picked IPs from DHCP and pingable from my laptop.
Attached are the screenshots for the same.
Thanks.
Do you have a proxy set in your browser, that is sending HTTP / HTTPS requests to that IP to a proxy server, instead of looking locally on your system?
Tried setting the proxy as well but that didnt help. I have another error at the console of the UCSPE as follows
Could this be an issue ?
Co
Eric
Hi Eric,
That did the trick. Thank you so much now i can connect via browser.
Thanks.
506
