UCS-SP7-B200-P expansion
Hello, we have a configuration as indicated in the table, and we want add two new blade to the current configuration. Can you tell me  what  is compatible with these ? or where i can read about compatible ?
UCS-SP7-B200-P UCS SP7 B200 PERF 2x6296 1xCH 4xB200w/2x2680v2 256G 1
UCS-SP-INFRA-CHSS UCS SP BASE 5108 Blade Svr AC Chassis 1
N01-UAC1  Single phase AC power module for UCS 5108 1
N20-CAK Accessory kit for UCS 5108 Blade Server Chassis 1
N20-CBLKB1  Blade slot blanking panel for UCS 5108/single slot 8
N20-FAN5  Fan module for UCS 5108 8
N20-FW011 UCS Blade Server Chassis FW Package 2.1 1
UCS-IOM-2208XP  UCS 2208XP I/O Module (8 External, 32 Internal 10Gb Ports) 2
UCSB-PSU-2500ACPL 2500W Platinum AC Hot Plug Power Supply for UCS 5108 Chassis 4
 CAB-AC-2500W-EU Power Cord, 250Vac 16A, Europe 4
UCS-SP7-INFR-FI96  (Not sold standalone) UCS 6296UP 2RU Fabric Int w/18p LIC 2
CAB-9K10A-EU  Power Cord, 250Vac, 10A CEE 7/7 Plug, EU 4
DS-SFP-FC8G-SW  8 Gbps Fibre Channel SW SFP+, LC 8
N10-MGT011  UCS Manager v2.1 2
SFP-10G-SR  10GBASE-SR SFP Module 4
SFP-H10GB-CU3M  10GBASE-CU SFP+ Cable 3 Meter 12
UCS-ACC-6296UP  UCS 6296UP Chassis Accessory Kit 2
UCS-BLKE-6200  UCS 6200 Series Expansion Module Blank 6
 UCS-FAN-6296UP  UCS 6296UP Fan Module 8
UCS-PSU-6296UP-AC  UCS 6296UP Power Supply/100-240VAC 4
UCS-SP7-SR-B200-P  (Not a standalone SKU) B200M3 w/ 2xE52680B16x16GBVIC1240 4
N20-BBLKD  UCS 2.5 inch HDD blanking panel 8
UCS-CPU-E52680B  2.80 GHz E5-2680 v2/115W 10C/25MB Cache/DDR3 1866MHz 8
UCS-M3-V2-LBL   4
 UCS-MR-1X162RZ-A  16GB DDR3-1866-MHz RDIMM/PC3-14900/dual rank/x4/1.5v 64
 UCBS-MLOM-40G-01  Cisco UCIS VIC 1240 modular LOM for M3 blade servers 4
 UCS-E27-300G15K-4  UCS SP7 300GB 6Gb SFF SAS 15K RPM HDD 4PAK 2
 UCS-E27-300GB-HDD3 (Not a standalone SKU) 300GB 6Gb SAS 15K RPM HDD  8
33
