Community Member
UCS status is diffrent in central than from CLI
Under the status tab in UCS Central it says
Discription:
Configuring Service Profile SP-Demo-Blade1(FSM:sam:dme:LsServerConfigure)
Status: ConfigureResolveIdentifiers
Stage discriptor:
Resolving identifiers from UCS Central(FSM-STAGE:sam:dme:LsServerConfigure:ResolveIdentifiers)
But the CLI tells me this.
FI-1-B /chassis/server # show fsm status
Slot: 1
Server: sys/chassis-1/blade-1
    FSM 1:
        Remote Result: Not Applicable
        Remote Error Code: None
        Remote Error Description:
        Status: Nop
        Previous Status: Turnup Success
        Timestamp: 2014-01-31T08:41:24.020
        Try: 0
        Flags: 0
        Progress (%): 100
        Current Task:
    FSM 2:
        Status: Nop
        Previous Status: Identify Success
        Timestamp: 2013-12-29T19:57:31.190
        Try: 0
        Progress (%): 100
        Current Task:
    FSM 3:
        Status: Nop
        Previous Status: Configure Success
        Timestamp: 2014-01-31T08:41:23.344
        Try: 0
        Flags: 0
        Progress (%): 100
        Current Task:
FI-1-B /chassis/server # show fsm task
Anyone know what is wrong?
1 REPLY
I would 100% trust CLI; it could just be a GUI problem ;-)
457
