ucs uplinks 4500X VSS
New deployment of a pair of 4500X in VSS mode and Cisco UCS.
FI-A has 1 10G link to each 4500X
FI-B has 1 10G link to each 4500X
How should the ports and port channels on the 4500X be configured for UCS uplinks?
Everyone's tags (3)
1 REPLY
Re: ucs uplinks 4500X VSS
Hi Reed,
In the end you will just create two port channels, one to each FI.
This is the documentation to create etherchannel on 4500X.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/15.02SG/configuration/guide/channel.html#wp1020670
The interfaces "Ten 1/1" of each 4500X will be part of the first etherchannel andin the second the interfaces "Ten 1/2". (This is just a representation not the real interface number).
Remeber to use the mode active (LACP) of the etherchannel, because this is enabled by default in the Fabric Interconnects.
Richard
1280
