UCS200 M2
     I need to change the IP address of my UCS 200 and for sme reason it will not work th e address is X.17.1.162 if I chnage to x.16.1.162 it fails if I change to x.17.1.242 it is okay.. So it looks like if I chnage the subnet it will not work..
Any ideas????? Or am I missing something?
1 REPLY
UCS200 M2
Please provide us more information on the non-working scenario.
Are you able to change the IP address successfully on CIMC ?
If yes, can you ping the 1.162 IP address from your PC ?
Did you verify the upstream network connectivity when you assign 1.162 IP address ?
Padma
515
