UCSB-PSU-2500ACPL versus N20-PAC5-2500W
MIKE MATHENY
Our older chassis have 5108 power supplies.
N20-PAC5-2500W
The newer chassis have 6508 power supplies.
UCSB-PSU-2500ACPL
We just plugged in the two new B420 blades and within two hours we are getting thermal faults.
What is the difference between these two power supplies?
Walter Dey
See
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/hw/chassis-install-guide/ucs5108_install/ucs5108_install_appendix_0100.html#ID256
Specifications for the Cisco UCS 5108 Blade Server Chassis Power Supply Units
Table 5 AC-input Gold Power Supply (N20-PAC5-2500W) Specifications
              Table 6 AC-input Platinum Power Supply (UCSB-PSU-2500ACPL) Specifications
Keny Perez
Level 8
Level 8
The thermal problems might not even be related to the PSUs themselves but instead a congestion in the I2C bus of the chassis.
Open an ssh session to UCSM and run the commands:
1-connect local a
2-connect iom #   <<< # is the chassis number where the IOM is affected
3-show platform software cmc showi2c
4-show platform software cmcctrl ohms all
5-Exit and try step 1 with "b" at the  end and use the same chassis # in step 2.
6-Post outcome here.
-Kenny
Please post as well the UCS firmware version ! a lot of this I2C bus problems should actually be fixed, at least in the newer versions.
I2c Software Fix
•Multiple symptoms across the system
•CSCue49366
•Fixed in 2.0.5b and 2.1.1f
Fan/Thermal
•CSCtx52556
•CSCtx49686
•CSCtl43716
•CSCua10675
PSU
•CSCtx90410
•CSCuc52899
I2C/HIF Flap
•CSCtq10987
Blade loss
CSCto6853
I2c Hardware Fix
Engineering Change Order was implemented in August 2011, additional HW changes to improve margins for i2c are in the following part/part numbers
2104 IOMs with fix PN 73-11623-08 and later have modification
22xx IOMs are unaffected
2500W PSUs with fix PN 341-0293-10 and later have modification
Platinum PSUs have I2C reset circuitry after timeout event
