UCSM Strange GUI Java Again?
since a few days I had UCSM Gui show up this way:
as you can see, no picture of the ucs chassi are shown.
I was used to see this from time to time buy now its seem permanant. (usualy reload get rid of this issue)
I tryed reinstalling Java version 7.25 to no avail.
flush java cache, use direct connect.  No change.
any ides are welcome.
Stephane Beausoleil
SysAdmin senior / Équipe Virtualisation
CGI
Stephane Beausoleil SysAdmin senior / Équipe Virtualisation CGI
1 ACCEPTED SOLUTION
Stephane,
thanks for posting the feedback. If possible, mark your post as "answered" so other future users can see you found the reason for the failure.
-Kenny
Note:
this issue seem to be Ucs domain related:
some others will display properly like this one:
until they get weird like the others.
thanks again for any help.
Stephane Beausoleil
CGI
Hey Solve my own issue,
when you uninstall Java some stuff is left behind in the "C:\Users\%username%\AppData\LocalLow\Sun\Java\deployment" Directory.
this is where the java cache is located. and no this problem is not flush with the cash clean-up.
so after unsintalling java deleted all in the java directory that was left. re-install and now everything is back to normal and speadyer to....
so thats it problem solved.
Thanks for looking.
Stephane Beausoleil
CGI
Stephane,
-Kenny
Done thanks.
Stephane
332
