Upgrade question 1010
I will be upgrading a pair of nexus 1010 and understand that this needs to be done frome the cimc connection. I do not see a copy command available in the cimc CLI to copy the image with. What am I missing.
  • Unified Computing
Re: Upgrade question 1010
Yes I am ssh to the cimc ineterface. When I do a ?  this is what is avialable
ucs-c200-m2#
  commit   Batch commit changes
  connect  Connect to other console
  discard  Discard all changes
  exit     Exit from command interpreter
  scope    Changes the current mode
  set      Set property values
  show     Show system information
  top      Go to the top mode
You haven't connected to the SOL yet...
Issue "connect host" - taken from the Doc above.  Then you'll see the appropriate commands available once correctly logged in via SOL.
Step 2 Connect to the Cisco Nexus 1010 CLI.
connect host
Robert
When I try to connect to host I get  "CISCO Serial Over LAN disabled"  am I missing some configuration?
Server# scope sol
Server /sol # set enabled yes
Server /sol *# set baud-rate 115200
Server /sol *# commit
Now it connects:
CISCO Serial Over LAN:
Close Network Connection to Exit
But I don't seem to get a response when I type
From the CIMC issue:
scope chassis
show detail
Paste the output
Robert
ucs-c200-m2# scope chassis
ucs-c200-m2 /chassis # show detail
Chassis:
    Power: on
    Serial Number: QCI1448A2RI
    Product Name: Virtual Services Appliance
    PID : N1K-C1010
    UUID: 7FF14634-4BF1-DF11-BFAF-C471FEB0D992
    Locator LED: off
    Description:
    Power Restore Policy: power-off
    Power Delay Type: fixed
    Power Delay Value(sec): 0
I had a similar issue and ran the same commands to enable sol on my first Nexus 1010. Before doing so on the second 1010, I ran the show command under scope sol and saw that it was set to 9600 baud. I changed to 9600 baud on the first Nexus 1010 and all worked ok. I guess 115200 doesn't work unless it's configured somewhere else. Hopefully this helps someone else who finds this thread
1634
