08-06-2012 11:57 PM - edited 03-01-2019 10:33 AM
I am going to install UCS with two Catalyst switches (3560G and 3750G). Do I make a peer-link port-channel between them? Is it a requirement for communication to work?
Is it a requirement to cable the port-channel coming from the FIs to each of the two switches? Or can I cable two links to the same uplink switch?
Plase reply soon as I am running out of time..
Message was edited by: Atle Dale
Solved! Go to Solution.
08-07-2012 01:09 AM
Hi Atle,
Yes we need a common l2 platforms for the vlans configure on the UCS since the two FI create two different fabric (A&B) and any traffic from A for blade on B and vice versa will need to be switched by the upstream switches. if you do not have a common point above the 3560 and the 3750 then you need to have a link between the two switches. Do make sure to allow the vlans (configure on ucs and others if required) on those ports as well as make sure the spanning-tree is not blocking them.
i am not very sure about your second questions, however on what ever i understand:
1) if you have multiple links going to the same switch its prefered to put them in a PO
2) since these switches are different and not in a VSS, you will need seprate Po for each switch.
Hope this helps!
./Abhinav
08-07-2012 01:09 AM
Hi Atle,
Hope this helps!
./Abhinav
08-07-2012 05:45 AM
thanks, this cleared it up!
